Banggood Micro Minim OSD [4 Dummies]
Corvus corax
Danke für den Tipp, banggood hat zwar kein Treiber angeboten, aber die Kommentare waren diesmal hilfreich:
http://www.ftdichip.com/Drivers/D2XX.htm
Jetzt wird alles korrekt erkannt. Aber es wird nur ein Bild ohne OSD angezeigt. Ich nutze RSSI über D4R, sowie BAT2 und Masse für die Spannungsanzeige und gewährleiste die 5V Versorgung. Hab ich vielleicht etwas vergessen oder falsch gemacht?
Code:
/*--------------------------       initialisation options      ----------------------------------------------------*/
// Ignore this section unless you know you need to use it !!
// This section contains initialisation options that only require to be run once.
// Once the initialisation has completed, all sections should be commented and the sketch re-uploaded.
//#define EEPROM_CLEAR             // Uncomment to force a wipe and reload of default settings at each OSD start. Same as EEPROM_CLEAR sketch.
//#define LOADFONT_DEFAULT         // Uncomment to force an upload of default font instead of using GUI
//#define LOADFONT_LARGE           // Uncomment to force an upload of large font instead of using GUI
/*--------------------------       configurable parameters      ----------------------------------------------------*/
/********************       OSD HARDWARE settings      *********************/
//Choose ONLY ONE option:
//#define MINIMOSD                    // Uncomment this if using standard MINIMOSD hardware (default for 95% of boards)
#define WITESPYV1                 // Uncomment this if using Witespy V1.1 OSD, select this to correct for both swapped bat1/bat 2 and to also use alternative resistors / pinouts.
//#define WITESPYMICRO              // Uncomment this if using Witespy Micro Minim OSD, select this to correct for swapped bat1/bat 2.
//#define RUSHDUINO                 // Uncomment this if using Rushduino
// NOTE-some of the popular RTFQ/Witespy boards have swapped bat1/bat2 pins and alternative voltage measuring resistors
// If having difficulties, first select default MINIMOSD as above, then use the following to correct:
// #define SWAPVOLTAGEPINS          // For boards with batt voltage appearing on vid voltage
// #define ALTERNATEDIVIDERS        // For boards with voltage unable to be adjusted high enough
/********************       CONTROLLER SOFTWARE      *********************/
// Choose ONLY ONE option:-
// Note - choose carefully to ensure correct settings are written to flight controller.
// The first three are for convenience - they set the OSD for the latest FC version.
// IMPORTANT - remember to update MWOSD when updating FC software!!
// Choose ONLY ONE option from the following long list :-
// latest release...
//#define MULTIWII                  // Uncomment this if you are using latest MULTIWII version from repository (2.4 at time of this MWOSD release)
//#define BASEFLIGHT                // Uncomment this if you are using latest BASEFLIGHT version from repository (Stable 2015.06.27 at time of this MWOSD release)
//#define CLEANFLIGHT               // Uncomment this if you are using latest CLEANFLIGHT version from repository (1.9.0 at time or this MWOSD release)
//#define HARIKIRI                  // Uncomment this if you are using HARIKIRI (for BOXNAMES compatibility)
//#define NAZA                      // Uncomment this if you are using NAZA flight controller
//#define GPSOSD_UBLOX              // Uncomment this if you are using a UBLOX GPS module for a GPS based OSD
//#define GPSOSD_NMEA               // Uncomment this if you are using a NMEA compatible GPS module for a GPS based OSD
//#define GPSOSD_MTK                // Uncomment this if you are using a MTK module for a GPS based OSD
#define NOCONTROLLER              // Uncomment this if you ahave nothing connected to the serial port - no controller or GPS module
// old releases supported...
//#define MULTIWII_V23              // Uncomment this if you are using MW versions 2.2/2.3
//#define MULTIWII_V21              // Uncomment this if you are using MW versions 2.0/2.1  (for BOXNAMES compatibility)
//#define BASEFLIGHT20150327        // Uncomment this if you are using BASEFLIGHT up to and including version Stable 2015.03.27
//#define CLEANFLIGHT172            // Uncomment this if you are using CLEANFLIGHT versions up to and including 1.7.2
//#define CLEANFLIGHT180            // Uncomment this if you are using CLEANFLIGHT versions 1.8.0 & 1.8.1
/********************       AIRCRAFT/INSTALLATION TYPE settings      *********************/
#define ROTORCRAFT                  // Default for multirotors etc.
//#define FIXEDWING                 // Uncomment this if you are using fixed wing MultiWii or Baseflight
/********************       HARDWARE CURRENT sensor settings      *********************/
#define AMPERAGEMAX     500         // Size of current sensor / maximum current draw (* 10) e.g. 50A sensor = 500, 100A sensor = 1000
#define AMPERAGEOFFSET  0           // Optional extra for high offset sensors not supported in GUI (typically bidirectional sensors use a value of 256-512)
/********************       OSD SCREEN SWITCH settings      *********************/
// This functionality enables :
// a, 2 different screen layouts to be selected using the Flight controller "OSD_SWITCH" feature or
// b, 2 or 3 different screen layouts to be selected using a specificed RC channel assigned to a TX switch
//#define OSD_SWITCH                // Uses original 2 way screen switch using OSD Switch via Flight Controller. MUST Ensure enabled on flight controller - e.g. #define OSD_SWITCH on multiwii
#define OSD_SWITCH_RC               // Enables 3 way screen switch using a TX channel via FC. Specify channel on GUI (range 0-7 AUX1=4 AUX4=7)
//#define OSD_SWITCH_RSSI           // Enables 3 way screen switch using a TX channel via a RX channel connected to the OSD RSSI pin. Typically used for GPSOSD.
/********************       GPS OSD settings      *********************/
//#define PPMOSDCONTROL             // Enables full OSD menu, screen switching, RSSI, Throttle fature, virtual current sensor, etc using a PPM signal into OSD RSSI pin
//#define SERIAL_SUM_PPM_RHF        // Enable for Robe/Hitec/Futaba
//#define SERIAL_SUM_PPM_GS         // Enable for Graupner/Spektrum
//#define SERIAL_SUM_PPM_M          // Enable for Multiplex
//#define SERIAL_SUM_PPM_HS         // Enable for Hitec/Sanwa
/********************       FILTER settings      *********************/
#define STAGE2FILTER                // Enable for smoother readings of voltage / current / RSSI.
//#define SMOOTHFILTER              // Enable for smoothest readings of voltage / current / RSSI. Uses more memory. Prototype
/********************       RSSI settings      *********************/
#define INTPWMRSSI                  // Undefine this to use new interrup PWM RSSI method (standard PWM 750-2250ms pulse width)
//#define PULSEINPWMRSSI            // Undefine this to use legacy non interrupt PWM RSSI method (pulse width 0 - 2250ms pulse width)
//#define FASTPWMRSSI               // Undefine this to use high PWM refresh frequency RSSI
/********************       GPS settings      *********************/
#define MINSATFIX 5                 // Number of sats required for a fix. 5 minimum. More = better
/********************       WARNING/STATUS settings      *********************/
#define SATACTIVECHECK              // Alerts if sats below MINSATFIX - in addition to flashing sat indicator
#define GPSACTIVECHECK 5            // Alerts if no GPS data for more than x secs. Sets GPS sats to zero
#define MSPACTIVECHECK 3            // Alerts if no Flight controller data for more than x secs.
#define DISP_LOW_VOLTS_WARNING      // Alerts if low voltage
#define FORCE_DISP_LOW_VOLTS        // Enable display low voltage warning override for screen layouts where its disabled
/********************       AIRCRAFT type=FIXEDWING settings      *********************/
// **ONLY** valid when using fixed wing
//#define USEMAGHEADING             // Undefine this to use MAG for FW heading instead of GPS (requires controller with MAG sensor)
//#define USEBAROALTITUDE           // Undefine this if you have a BARO to use BARO for FW altitude instead of GPS (requires controller with BARO sensor) ** Recommended **
//#define USEGLIDESCOPE 40          // Enables ILS glidescope where 40 = 4.0° glidescope. 1.0 deg gradiented scope scale
//#define DISABLEGPSALTITUDERESET   // Disables automatic reset of GPS Altitude to zero at arm for FC that already provide this functionality.
/******************** Serial speed settings *********************/
#define BAUDRATE 115200
//#define BAUDRATE 57600
//#define BAUDRATE 38400
//#define BAUDRATE 19200
//#define BAUDRATE 9600
/******************** Serial MSP speed settings *********************/
// Choose ONLY ONE option: increases speeds of serial update - but with impact to flight controller
#define MSP_SPEED_LOW
//#define MSP_SPEED_MED
//#define MSP_SPEED_HIGH
/********************       CALLSIGN settings      *********************/
#define   CALLSIGNINTERVAL 60      // How frequently to display Callsign (in seconds)
#define   CALLSIGNDURATION 4       // How long to display Callsign (in seconds)
//#define CALLSIGNALWAYS           // Alternative option - enable to permanently display callsign.
//#define FREETEXTLLIGHTS          // Alternative option - enable to display freetext (or callsign) when LLIGHTS Switch active on TX.
//#define FREETEXTGIMBAL           // Alternative option - enable to display freetext (or callsign) when GIMBAL Switch active on TX.
/********************       STARTUP settings      *********************/
//#define INTRO_VERSION               "MWOSD - DEV 1.5.1" // Call the OSD something else if you prefer. KVOSD is not permitted - LOL.
//#define INTRO_CALLSIGN            // Enable to display callsign at startup
//#define INTRO_TIMEZONE            // Enable to display timezone at startup - if GPS TIME is enabled
//#define INTRO_DELAY 5             // Seconds intro screen should show for. Default is 10
#define INTRO_MENU                  // Enable to display TX stick MENU
//#define STARTUPDELAY 2000         // Enable alternative startup delay (in ms) to allow MAX chip voltage to rise fully and initialise before configuring
/********************       I2CGPS type settings      *********************/
//#define I2CGPS_SPEED              // Uncomment this if you are using older I2CGPS - and need to correct for speed error (10x too slow)
//#define I2CGPS_DISTANCE           // Uncomment this if you are using older I2CGPS - and need to correct for distance error (650m max) UNTESTED
/********************       MAP MODE Settings       *********************/
//#define MAPMODENORTH              // Enable to use North as MAP reference in MODE 1 instead of take off direction (Default = disable)
/********************       FEATURES      *********************/
// Disable features if you require memory for other features
// Further configuration may be require elsewhere in config.h + option enabled on GUI
#define SBDIRECTION     // Enable/disable sidebar indicators (changes in speed or altitude)
#define HORIZON         // Enable/disable HORIZON indicator
#define MAPMODE         // Enable/disable MAP MODE - map indication of relative positions of home and aircraft
//#define GPSTIME       // Enable/disable GPS Time functions
//#define SPORT         // Enable/disable FRSKY S.PORT cell code
/********************       Display Settings         ************************/
#define MAXSTALLDETECT              // Enable to attempt to detect MAX chip stall from bad power. Attempts to restart.
//#define AUTOCAM                   // Disable if no screen display. Enables autodetect Camera type PAL/NTSC. Overrides GUI/OSD settings.
//#define AUTOCAMWAIT               // **UNTESTED** - Use with AUTOCAM - waits until camera is ready - i.e. if power up cameras after FC.
#define DECIMAL '.'                 // Decimal point character, change to what suits you best (.) (,)
#define USE_VSYNC                   // Disable if no screen display. Removes sparklies as updates screen during blanking time period.
//#define SHIFTDOWN                 // Select if your monitor cannot display top line fully. It shifts top 3 lines down. Not suitable for all layouts
//#define ALT_CENTER                // Enable alternative center crosshair
//#define FORCECROSSHAIR            // Forces a crosshair even if no AHI / horizon used
//#define HIDEARMEDSTATUS           // Enable to hide ARMED / DISARMED status
//#define FASTPIXEL                 // Optional - may improve resolution - especially hi res cams
//#define WHITEBRIGHTNESS 0x00      // Optional change from default 0x00=120%,0x01=100%,0x10=90%,0x11=80%  default is 0x01=100%
//#define BLACKBRIGHTNESS 0x00      // Optional change from default 0x00=0%,0x01=10%,0x10=20%0x11=30%  default is 0x00=0%
//#define FULLAHI                   // Enable to display a slightly longer AHI line
//#define I2CERROR 3                // Autodisplay Mutltiwii I2C errors if exceeds specified count
//#define SHORTSTATS                // Display only timer on flight summary
//#define FASTMSP                   // Enable for soft serial / slow baud rates if don't need GPS/BARO/HORIZON data. Speeds up remainder
//#define NOTHROTTLESPACE           // Enable to remove space between throttle symbol and the data
//#define REVERSEAHI                // Reverse pitch / roll direction of AHI - for DJI / Eastern bloc OSD users
//#define DISPLAY_PR                // Display pitch / roll angles. Requires relevant layout ppositions to be enabled
//#define AHICORRECT 10             // Enable to adjust AHI on display to match horizon. -10 = -1 degree
#define AHIPITCHMAX 200             // Specify maximum AHI pitch value displayed. Default 200 = 20.0 degrees
#define AHIROLLMAX  400             // Specify maximum AHI roll value displayed. Default 400 = 40.0 degrees
#define APINDICATOR                 // Enable to display AUTOPILOT instead of RTH distance
/********************       NAZA Settings         ************************/
//#define NAZAMODECONTROL           // Enables NAZA mode control display using a PWM signal into OSD RSSI pin. Can be used with OSD_SWITCH_RSSI
#define NAZA_MODE_GPS 1600
#define NAZA_MODE_ATI
#define NAZA_MODE_MAN 1400
/********************       FrSky S.Port settings      *********************/
//enables data transfer from frsky reciever s.port to osd via multiwii
//requires serial inverter cable & multiwii with s.port code
//Auto detected cell graph from s.port, 16 steps @ 0.05v
//To show battery voltage from s.port, enable "Use MWii" under "Main Voltage" in GUI
//To show amperage from s.port, enable "Use MWii" under Amperage in GUI
//more details: [url]http://code.google.com/p/scarab-osd/wiki/Frsky_SPort[/url]
#define MIN_CELL 320 //Cell Low Flash - No decimal, 3 Digits ie 320 = 3.20v
/********************  TEMPERATURE  settings      *********************/
//#define TEMPSENSOR                // Enable if you have a hardware temperature sensor - DEPRECATED
#define TEMPERATUREMAX 50           // Temperature warning value
Sorry, die Forensoftware bietet insuffizienterweise keine Spoilerfunktion an ...
Corvus corax
Wenn das osd auf NTSC steht und du PAL benutzt, dann kommt nur das cam Bild aber kein overlay.
Das habe ich eben mal getestet. Wenn in der GUI auf NTSC steht, da wird nur Bild ohne OSD (kein Overlay) geliefert, sowohl im PAL und im NTSC Mode des Bildschirms. Das gleiche gilt, wenn ich in der GUI das Ganze auf PAL stelle.
Wird alles korrekt erkannt und gespeichert in der GUI, ist alles wie gewünscht konfiguriert, aber es kommt nichts davon beim FPV-Bild an. :(
Corvus corax
Hallo Arakon,
Eine ganz normale Runcam, vermutlich im PAL-Mode.
Edit: Meine neue Hoffnung ist, dass alle nicht angelöteten Masseverbindungen die Ursache sind, laut:
http://fpvlab.com/forums/showthread.php?43773-Micro-minim-osd-no-overlay
Bis jetzt haben sich zwei Lötpads verabschiedet. Es sind aktuell 3 weitere Micro OSDs auf den Weg zu mir. Die Vielzahl der Funktionen, die Abmessungen und der Preis überzeugen mich absolut trotz des momentanen Problems.
acromaster2013
Eine dumme Frage hätte ich ja noch. Müssen die 5 Volt von der Flip kommend mit angeklemmt werden, (Kontaktreihe Gnd/v/rx/tx) oder kann ich nur tx, RX von der FC an das Osd kontaktieren und die 5 Volt von einem Spannungsregler, da das Osd500 mah braucht.?Beides ist Blödsinn, oder?
acromaster2013
Das ist jetzt Doppel Posting, sorry aber... Evtl lesen das hier ja andere Kollegen mit.
Mein Micro minimosd läuft zwar, kann aber nicht überflashen . Wollte noch mal clear eeprom und dann Firmware. Arduino Balken (Flash vorgang) fängt an zu laufen und bleibt bei ca 90 % stehen. Flash t nicht zu Ende. Keine Fehlermeldung. Upload Button und der arduino Software bleibt gelb. Bei Versuch die Firmware des Micro minimosd aufzuspielen /gleiches Spiel.
Ansonsten läuft das Ding.
Des weiteren :Wenn kein Gps angeschlossen ist, erscheint dann im OSD DISPLAY auch kein Satelliten Symbol? In der Gui Vorschau ist es zu sehen.
Anderen Ftdi Adapter auch schon probiert, sowie ältere Arduino Software.
Kurzer Nachtrag, innerhalb der Gui, wenn ich hier etwas ändere und auf write gehe, schreibt er das auch erfolgreich in die Platine. Jemand ne Idee woran es liegt das der Flash Vorgang nicht durchläuft?
profdrdenis
Direkt vorneweg, ich habe (noch) kein Micro miniOSD.
Lese hier aber von Konfiguration mittels Software, aber wie verbinde ich sie mit dem OSD? Oder geht dies nur über den USB Anschluß des Flug Kontrollers?
Wer erlöst mich von dem (Echtholz) Brett vor meinem Kopf?
