Gofilm 20 Parameters
Model Gofilm 20
FC CADDXF4_AIO_ELRS
VTX Moonlight Kit
Wheelbase 94mm
Motor 1303 6000KV
Propeller HQprop T2×2×3
Weight 115±5g
Size 133×123×39mm
Flight time 4S 650mAh & about 5.5 minutes
Receiver ELRS 2.4G
Battery interface XT30
FC Parameters
MCU STM32F405RGT6
GYRO and IMU ICM42688
Barometer BMP280
ExpressLRS receiver ELRS V3.0 UART
ESC 20A 4-IN-1
Blackbox 8MBp
Support Power 2~4S Lipo/Lihv
Mounting hole Distance 25.5×25.5mm
Firmware target CADDXF4_AIO_ELRS
VTX Parameters
Model Moonlight Kit
Firmware name AvatarMoonlight_Sky_X.X.X
Communication Frequency 5.725-5.850 GHz
Transmitter Power (EIRP) FCC: <30dBm; CE: <14dBm; SRRC: <20dBm; MIC: <25dBm
I/O Interface JST1.0*4(power cable); JST0.8*6(USB);microSD Card Slot; IPEX-1
Sensor Starlight sensor
FOV Max 160°
Aperture F2.1
Shutter Rolling shutter
ISO 100-25600
Recording resolution 4K@30/60fps; 2.7K@30/60fps;
1080p@100/60fps; 720p@60fps
Max Mbps 150Mbps
Video format MP4 (H.264)
3D DNR Support
Gyro flow Support
Built-in EIS Support
Wide Power Input 7.4V-25.2V
Power consumption 12V@1.4A, 8V@2.2A
Memory card type U3 microSD, Max 256G
camera size 19.6mm×19mm×24mm
VTX size 15.3mm×34.5mm×34.5mm
VTX Installation hole 20×20mm/25×25mm (M2)
Weight 38.5g (Antenna not included)
OSD Canvas mode
Latency Average delay 22ms
Antenna 2 (IPEX)
Model Gofilm 20
FC CADDXF4_AIO_ELRS
VTX Moonlight Kit
Wheelbase 94mm
Motor 1303 6000KV
Weight 115±5g
Size 133×123×39mm
Receiver ELRS 2.4G
FC Parameters
MCU STM32F405RGT6
Barometer BMP280
ESC 20A 4-IN-1
Blackbox 8MBp
VTX Parameters
Model Moonlight Kit
FOV Max 160°
Aperture F2.1
ISO 100-25600
Max Mbps 150Mbps
3D DNR Support
Gyro flow Support
OSD Canvas mode
Antenna 2 (IPEX)
