Filament vom King??
chrissi
Hat schon Jemand das ABS bzw. PTA Filament vom King getestet und kann etwas dazu sagen?
Der Preis scheint erstmal ok zu sein...
donandi
loading...███▒▒&#961
wahnsinn, der HK, hab´s schon gesehen bei den buddy codes, hätte dich eh gefragt, ob das was taugt. ist auf jeden fall sehr günstig.
donandi
ich konnte nicht widerstehen wenn ihr alle bestellt, und hab auch zugeschlagen :)
donandi
hab meine buddycodes gleich eingetragen, viel spass beim bestellen :p
So hier mal eine Zusammenfassung von eSun Filament auf amazon.com:
PLA:
Awesome PLA, nice packaging, vacuum sealed and works great
PLA:
Low priced filament can be a gamble, but in my limited tests so far this brand seems to be a good bet. The diameter is spot on, and I haven't yet encountered any of the issues I've seen with other filament brands at a similar price point (cross wound spools, nozzle clogging). Delivery was prompt, and the clear spools make it very easy to determine just how much filament you have left.
PLA:
Pros: Good color and prints well. Finished part looks good. Good layer bonding and overall part strength. pricing is competitive.
Cons: Support material is difficult to remove. Requires more time and effort to clean up a finished print than other brands.
Conclusion: I will use this material for parts that don't require a lot of support material but need to have a good quality appearance.
PLA:
Truly awesome filament, we have bought several rolls from this manufacturer and each one of them keeps the quality we are looking for, also the price is right and comes well packaged. Will certainly buy again.
PLA:
Random brittle areas jammed my 3D Printer with a Bowden extruder.
ABS:
It contained a lot of moisture and bubbled even thou it was well packaged and vacuum sealed. Overall not bad. Drying it out in my storage container and will try again.
Leider erst wenige Bewertungen, aber bei 6 Produkten ca 4 positive und 2 negative... Ist halt schwer einzuschätzen bei den wenigen Kommentaren.
PLA scheint insgesamt besser wegzukommen als ABS.
donandi
wow, das liets sich doch schon mal ganz ordentlich. so viel kann man ja bei dem preis nicht falsch machen
locomarco
Hab auch mal 3 Rollen bestellt. Mit Versand entspricht der Kilopreis etwa dem PLA von dasfilament.
Jetzt muss das Zeug nur noch etwas taugen.
Finde gut dass das nur 500g Rollen sind.
Arakon
Naja, Amazonbewertungen sagen nicht viel aus.. da ist auch einer dabei, der Nunus negativ bewertet, weil es absolut nicht druckbar sei und sein Drucker nur das Filament schreddert.. das gleiche Zeug druckt bei mir perfekt.
RCLogger
Oben
