// --------- 6 - Voltages & Current sensor settings ---------
// ***** 6.1 - Voltage Reference to measure voltages and current *****
//#define USE_INTERNAL_REFERENCE // uncomment this line if you use 1.1 volt internal reference instead of Vcc
//#define USE_EXTERNAL_REFERENCE // uncomment this line if you use an external reference instead of Vcc
#define REFERENCE_VOLTAGE 4970 // set value in milliVolt; if commented, oXs will use or 1100 (if internal ref is used) or 5000 (if internal ref is not used)
// ***** 6.2 - Voltage parameters *****
#define PIN_VOLTAGE 3 , 2 , 1 , 8 , 8 , 8 // set this line as comment if no one voltage have to be measured, set the value to 8 for the voltage(s) not to be measured.
#define RESISTOR_TO_GROUND 0 , 10 , 47 , 0 , 0 , 0 // set value to 0 when no divider is used for a voltage, can contains decimals
#define RESISTOR_TO_VOLTAGE 0 , 10 , 100 , 0 , 0 , 0 // set value to 0 when no divider is used for a voltage, can contains decimals
#define OFFSET_VOLTAGE 0 , 0 , 0 , 0 , 0 , 0 // optionnal, can be negative, must be integer
#define SCALE_VOLTAGE 1 , 1 , 1 , 1 , 1 , 1 // optionnal, can be negative, can have decimals
// ***** 6.3 - Max number of Lipo cells to measure (and transmit to Tx) *****
#define NUMBEROFCELLS 3 // Put this line as comment or set value to 0 (zero) if you do not want to transmit cell voltages.
