rx5808-pro : Deluxe BOSCAM rx5808 32CH SPI Steuerung mit Arduino und TV out.
Und der Fix von Fix:
Code:
 * SPI driver based on fs_skyrf_58g-main.c Written by Simon Chambers
 * TVOUT by Myles Metzel
 * Scanner by Johannes Hermen
 * Inital 2 Button version by Peter (pete1990)
 * Refactored and GUI reworked by Marko Hoepken
 * Universal version my Marko Hoepken
 * Raceband added by Johannes Hermen
The MIT License (MIT)
Copyright (c) 2015 Marko Hoepken
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
#define DEBUG
#include <TVout.h>
#include <fontALL.h>
#include <avr/pgmspace.h>
#include <EEPROM.h>
#define spiDataPin 10
#define slaveSelectPin 11
#define spiClockPin 12
#define rssiPin A6
// this two are minimum required
#define buttonSeek 2
#define buttonMode 3
// optional comfort buttons
#define buttonDown 4
#define buttonSave 5
// Buzzer
#define buzzer 6
// pins for DIP switch
#define dip_ch0 A0
#define dip_ch1 A1
#define dip_ch2 A2
#define dip_band0 A3
#define dip_band1 A4
#define dip_enable A5
// key debounce delay in ms
// NOTE: good values are in the range of 100-200ms
// shorter values will make it more reactive, but may lead to double trigger
#define KEY_DEBOUNCE 200
// Set you TV format (PAL = Europe = 50Hz, NTSC = INT = 60Hz)
//#define TV_FORMAT NTSC
#define TV_FORMAT PAL
#define led 13
// RSSI default raw range
#define RSSI_MIN_VAL 90
#define RSSI_MAX_VAL 300
// 75% threshold, when channel is printed in spectrum
#define RSSI_SEEK_FOUND 75
// 80% under max value for RSSI
#define RSSI_SEEK_TRESHOLD 80
// scan loops for setup run
#define RSSI_SETUP_RUN 10
#define STATE_SEEK_FOUND 0
#define STATE_SEEK 1
#define STATE_SCAN 2
#define STATE_MANUAL 3
#define STATE_SWITCH 4
#define STATE_SAVE 5
#define STATE_RSSI_SETUP 6
#define START_STATE STATE_SEEK
#define MAX_STATE STATE_MANUAL
#define CHANNEL_BAND_SIZE 8
#define CHANNEL_MIN_INDEX 0
#define CHANNEL_MAX_INDEX 39
#define CHANNEL_MAX 39
#define CHANNEL_MIN 0
#define TV_COLS 128
#define TV_ROWS 96
#define TV_Y_MAX TV_ROWS-1
#define TV_X_MAX TV_COLS-1
#define TV_SCANNER_OFFSET 14
#define SCANNER_BAR_SIZE 52
#define SCANNER_LIST_X_POS 4
#define SCANNER_LIST_Y_POS 16
#define SCANNER_MARKER_SIZE 2
#define EEPROM_ADR_STATE 0
#define EEPROM_ADR_TUNE 1
#define EEPROM_ADR_RSSI_MIN_L 2
#define EEPROM_ADR_RSSI_MIN_H 3
#define EEPROM_ADR_RSSI_MAX_L 4
#define EEPROM_ADR_RSSI_MAX_H 5
//#define DEBUG
// Channels to sent to the SPI registers
const uint16_t channelTable[] PROGMEM = {
  // Channel 1 - 8
  0x2A05,    0x299B,    0x2991,    0x2987,    0x291D,    0x2913,    0x2909,    0x289F,    // Band A
  0x2903,    0x290C,    0x2916,    0x291F,    0x2989,    0x2992,    0x299C,    0x2A05,    // Band B
  0x2895,    0x288B,    0x2881,    0x2817,    0x2A0F,    0x2A19,    0x2A83,    0x2A8D,    // Band E
  0x2906,    0x2910,    0x291A,    0x2984,    0x298E,    0x2998,    0x2A02,    0x2A0C,    // Band F / Airwave
  0x281D,    0x288F,    0x2902,    0x2914,    0x2978,    0x2999,    0x2A0C,    0x2A1E     // Band R / Immersion Raceband
// Channels with their Mhz Values
const uint16_t channelFreqTable[] PROGMEM = {
  // Channel 1 - 8
  5865, 5845, 5825, 5805, 5785, 5765, 5745, 5725, // Band A
  5733, 5752, 5771, 5790, 5809, 5828, 5847, 5866, // Band B
  5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945, // Band E
  5740, 5760, 5780, 5800, 5820, 5840, 5860, 5880, // Band F / Airwave
  5658, 5695, 5732, 5769, 5806, 5843, 5880, 5917  // Band R / Immersion Raceband
// do coding as simple hex value to save memory.
const uint8_t channelNames[] PROGMEM = {
  0xA1, 0xA2, 0xA3, 0xA4, 0xA5, 0xA6, 0xA7, 0xA8,
  0xB1, 0xB2, 0xB3, 0xB4, 0xB5, 0xB6, 0xB7, 0xB8,
  0xE1, 0xE2, 0xE3, 0xE4, 0xE5, 0xE6, 0xE7, 0xE8,
  0xF1, 0xF2, 0xF3, 0xF4, 0xF5, 0xF6, 0xF7, 0xF8,
  0xC1, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8
// All Channels of the above List ordered by Mhz
const uint8_t channelList[] PROGMEM = {
  19, 18, 32, 17, 33, 16, 7, 34, 8, 24, 6, 9, 25, 5, 35, 10, 26, 4, 11, 27, 3, 36, 12, 28, 2, 13, 29, 37, 1, 14, 30, 0, 15, 31, 38, 20, 21, 39, 22, 23
uint8_t channel = 0;
uint8_t channelIndex = 0;
uint8_t rssi = 0;
uint8_t rssi_scaled = 0;
uint8_t hight = 0;
uint8_t state = START_STATE;
uint8_t state_last_used=START_STATE;
uint8_t last_state= START_STATE+1; // force screen draw
uint8_t writePos = 0;
uint8_t switch_count = 0;
uint8_t man_channel = 0;
uint8_t last_channel_index = 0;
uint8_t force_seek=0;
unsigned long time_of_tune = 0;        // will store last time when tuner was changed
uint8_t last_maker_pos=0;
uint8_t last_active_channel=0;
uint8_t first_channel_marker=1;
uint8_t update_frequency_view=0;
uint8_t seek_found=0;
uint8_t last_dip_channel=255;
uint8_t last_dip_band=255;
uint8_t scan_start=0;
uint8_t first_tune=1;
uint8_t force_menu_redraw=0;
uint16_t rssi_min=0;
uint16_t rssi_max=0;
uint16_t rssi_setup_min=0;
uint16_t rssi_setup_max=0;
uint16_t rssi_seek_found=0;
uint16_t rssi_setup_run=0;
TVout TV;
// SETUP ----------------------------------------------------------------------------
void setup()
    // IO INIT
    // initialize digital pin 13 LED as an output.
    pinMode(led, OUTPUT); // status pin for TV mode errors
    // buzzer
    pinMode(buzzer, OUTPUT); // Feedback buzzer (active buzzer, not passive piezo)
    digitalWrite(buzzer, HIGH);
    // minimum control pins
    pinMode(buttonSeek, INPUT);
    digitalWrite(buttonSeek, INPUT_PULLUP);
    pinMode(buttonMode, INPUT);
    digitalWrite(buttonMode, INPUT_PULLUP);
    // optional control
    pinMode(buttonDown, INPUT);
    digitalWrite(buttonDown, INPUT_PULLUP);
    pinMode(buttonSave, INPUT);
    digitalWrite(buttonSave, INPUT_PULLUP);
    // dip switches
    pinMode(dip_ch0, INPUT);
    digitalWrite(dip_ch0, INPUT_PULLUP);
    pinMode(dip_ch1, INPUT);
    digitalWrite(dip_ch1, INPUT_PULLUP);
    pinMode(dip_ch2, INPUT);
    digitalWrite(dip_ch2, INPUT_PULLUP);
    pinMode(dip_band0, INPUT);
    digitalWrite(dip_band0, INPUT_PULLUP);
    pinMode(dip_band1, INPUT);
    digitalWrite(dip_band1, INPUT_PULLUP);
    pinMode(dip_enable, INPUT);
    digitalWrite(dip_enable, INPUT_PULLUP);
#ifdef DEBUG
    Serial.begin(115200);
    Serial.println(F("START:"));
#endif
    // SPI pins for RX control
    pinMode (slaveSelectPin, OUTPUT);
    pinMode (spiDataPin, OUTPUT);
  pinMode (spiClockPin, OUTPUT);
    // tune to first channel
    // init TV system
    char retVal = TV.begin(TV_FORMAT, TV_COLS, TV_ROWS);
    // 0 if no error.
    // 1 if x is not divisable by 8.
    // 2 if y is to large (NTSC only cannot fill PAL vertical resolution by 8bit limit)
    // 4 if there is not enough memory for the frame buffer.
    if (retVal > 0) {
        // on Error flicker LED
        while (true) { // stay in ERROR for ever
            digitalWrite(13, !digitalRead(13));
            delay(100);
    TV.select_font(font4x6);
    // Setup Done - LED ON
    digitalWrite(13, HIGH);
    // use values only of EEprom is not 255 = unsaved
    uint8_t eeprom_check = EEPROM.read(EEPROM_ADR_STATE);
    if(eeprom_check == 255) // unused
        EEPROM.write(EEPROM_ADR_STATE,START_STATE);
        EEPROM.write(EEPROM_ADR_TUNE,CHANNEL_MIN_INDEX);
        // save 16 bit
        EEPROM.write(EEPROM_ADR_RSSI_MIN_L,lowByte(RSSI_MIN_VAL));
        EEPROM.write(EEPROM_ADR_RSSI_MIN_H,highByte(RSSI_MIN_VAL));
        // save 16 bit
        EEPROM.write(EEPROM_ADR_RSSI_MAX_L,lowByte(RSSI_MAX_VAL));
        EEPROM.write(EEPROM_ADR_RSSI_MAX_H,highByte(RSSI_MAX_VAL));
    // debug reset EEPROM
    //EEPROM.write(EEPROM_ADR_STATE,255);
    // read last setting from eeprom
    state=EEPROM.read(EEPROM_ADR_STATE);
    channelIndex=EEPROM.read(EEPROM_ADR_TUNE);
    rssi_min=((EEPROM.read(EEPROM_ADR_RSSI_MIN_H)<<8) | (EEPROM.read(EEPROM_ADR_RSSI_MIN_L)));
    rssi_max=((EEPROM.read(EEPROM_ADR_RSSI_MAX_H)<<8) | (EEPROM.read(EEPROM_ADR_RSSI_MAX_L)));
    force_menu_redraw=1;
// LOOP ----------------------------------------------------------------------------
void loop()
    /*   Mode Select   */
    state_last_used=state; // save save settings
    if (digitalRead(buttonMode) == LOW) // key pressed ?
        beep(50); // beep & debounce
        delay(KEY_DEBOUNCE/2); // debounce
        // on entry wait for release
        while(digitalRead(buttonMode) == LOW)
                // wait for MODE release
        #define MAX_MENU 4
        #define MENU_Y_SIZE 15
        uint8_t menu_id=0;
        // Show Mode Screen
        if(state==STATE_SEEK_FOUND)
            state=STATE_SEEK;
        uint8_t in_menu=1;
        uint8_t in_menu_time_out=10; // 10x 200ms = 2 seconds
        Enter Mode menu
        Show current mode
        Change mode by MODE key
        Any Mode will refresh screen
        If not MODE changes in 2 seconds, it uses last selected mode
        do
            TV.clear_screen();
            // simple menu
            TV.select_font(font8x8);
            TV.draw_rect(0,0,127,95,  WHITE);
            TV.draw_line(0,14,127,14,WHITE);
            TV.printPGM(10, 3,  PSTR("MODE SELECTION"));
            TV.printPGM(10, 5+1*MENU_Y_SIZE, PSTR("Auto Search"));
            TV.printPGM(10, 5+2*MENU_Y_SIZE, PSTR("Band Scanner"));
            TV.printPGM(10, 5+3*MENU_Y_SIZE, PSTR("Manual Mode"));
            TV.printPGM(10, 5+4*MENU_Y_SIZE, PSTR("Switch Mode"));
            TV.printPGM(10, 5+5*MENU_Y_SIZE, PSTR("Save Setup"));
            // selection by inverted box
            switch (menu_id)
                case 0: // auto search
                    TV.draw_rect(8,3+1*MENU_Y_SIZE,100,12,  WHITE, INVERT);
                    state=STATE_SEEK;
                    force_seek=1;
                    seek_found=0;
                break;
                case 1: // Band Scanner
                    TV.draw_rect(8,3+2*MENU_Y_SIZE,100,12,  WHITE, INVERT);
                    state=STATE_SCAN;
                    scan_start=1;
                break;
                case 2: // manual mode
                    TV.draw_rect(8,3+3*MENU_Y_SIZE,100,12,  WHITE, INVERT);
                    state=STATE_MANUAL;
                break;
                case 3: // DIP mode
                    TV.draw_rect(8,3+4*MENU_Y_SIZE,100,12,  WHITE, INVERT);
                    state=STATE_SWITCH;
                    last_dip_channel=255; // force update
                break;
                case 4: // Save settings
                    TV.draw_rect(8,3+5*MENU_Y_SIZE,100,12,  WHITE, INVERT);
                    state=STATE_SAVE;
                break;
            } // end switch
            while(--in_menu_time_out && (digitalRead(buttonMode) == HIGH)) // wait for next mode or time out
                delay(200); // timeout delay
            if(in_menu_time_out==0)
                in_menu=0; // EXIT
                beep(KEY_DEBOUNCE/2); // beep & debounce
                delay(50); // debounce
            else // no timeout, must be keypressed
                delay(KEY_DEBOUNCE); // debounce
                /*   Menu handler   */
                if (menu_id < MAX_MENU)
                    menu_id++; // next state
                else
                    menu_id = 0;
        } while(in_menu);
        last_state=255; // force redraw of current screen
        switch_count = 0;
        // clean line?
        TV.print(TV_COLS/2, (TV_ROWS/2), "             ");
    else // key pressed
    { // reset debounce
        switch_count = 0;
    /*   Static SWITCH MODE   */
    // set to SWITCH mode if SWITCH_ENABLE is low (no interactive mode)
    if(digitalRead(dip_enable) == LOW)
        state=STATE_SWITCH;
    /*     Save buttom     */
    // hardware save buttom support (if no display is used)
    if(digitalRead(buttonSave) == LOW)
        state=STATE_SAVE;
    /*   Draw screen if mode has changed   */
    if(force_menu_redraw || state != last_state)
        /*   Main screen draw   */
        // changed state, clear an draw new screen
        TV.clear_screen();
        // simple menu
        #define TV_Y_GRID 14
        #define TV_Y_OFFSET 3
        switch (state)
            case STATE_SCAN: // Band Scanner
            case STATE_RSSI_SETUP: // RSSI setup
                TV.draw_rect(0,0,TV_X_MAX,1*TV_Y_GRID,  WHITE); // upper frame
                if(state==STATE_SCAN)
                    TV.printPGM(10, TV_Y_OFFSET,  PSTR(" BAND SCANNER"));
                else
                    TV.printPGM(10, TV_Y_OFFSET,  PSTR("  RSSI SETUP "));
                    TV.print(10, SCANNER_LIST_Y_POS, "RSSI Min:     RSSI Max:   ");
                    // prepare new setup
                    rssi_min=0;
                    rssi_max=400; // set to max range
                    rssi_setup_min=400;
                    rssi_setup_max=0;
                    rssi_setup_run=RSSI_SETUP_RUN;
                TV.draw_rect(0,1*TV_Y_GRID,TV_X_MAX,9,  WHITE); // list frame
                TV.draw_rect(0,TV_ROWS - TV_SCANNER_OFFSET,TV_X_MAX,13,  WHITE); // lower frame
                TV.print(2, (TV_ROWS - TV_SCANNER_OFFSET + 2), "5645");
                TV.print(57, (TV_ROWS - TV_SCANNER_OFFSET + 2), "5800");
                TV.print(111, (TV_ROWS - TV_SCANNER_OFFSET + 2), "5945");
                // trigger new scan from begin
                channel=CHANNEL_MIN;
                writePos=SCANNER_LIST_X_POS; // reset channel list
                channelIndex = pgm_read_byte_near(channelList + channel);
                scan_start=1;
            break;
            case STATE_MANUAL: // manual mode
            case STATE_SEEK: // seek mode
            case STATE_SWITCH: // SWITCH mode
                TV.draw_rect(0,0,TV_X_MAX,TV_Y_MAX,  WHITE); // outer frame
                if (state == STATE_MANUAL)
                    TV.printPGM(10, TV_Y_OFFSET,  PSTR(" MANUAL MODE"));
                else if(state == STATE_SEEK)
                    TV.printPGM(10, TV_Y_OFFSET,  PSTR("AUTO MODE SEEK"));
                else if(state == STATE_SWITCH)
                    TV.printPGM(10, TV_Y_OFFSET,  PSTR("  SWITCH MODE "));
                TV.draw_line(0,1*TV_Y_GRID,TV_X_MAX,1*TV_Y_GRID,WHITE);
                TV.printPGM(5,TV_Y_OFFSET+1*TV_Y_GRID,  PSTR("BAND: "));
                TV.draw_line(0,2*TV_Y_GRID,TV_X_MAX,2*TV_Y_GRID,WHITE);
                TV.printPGM(5 ,TV_Y_OFFSET-1+2*TV_Y_GRID,  PSTR("1 2 3 4 5 6 7 8"));
                TV.draw_line(0,3*TV_Y_GRID,TV_X_MAX,3*TV_Y_GRID,WHITE);
                TV.printPGM(5,TV_Y_OFFSET+3*TV_Y_GRID,  PSTR("FREQ:     GHz"));
                TV.draw_line(0,4*TV_Y_GRID,TV_X_MAX,4*TV_Y_GRID,WHITE);
                TV.printPGM(5,TV_Y_OFFSET+4*TV_Y_GRID,  PSTR("RSSI:"));
                TV.draw_line(0,5*TV_Y_GRID-4,TV_X_MAX,5*TV_Y_GRID-4,WHITE);
                // frame for tune graph
                update_frequency_view=1;
                force_seek=1;
            break;
            case STATE_SAVE:
                EEPROM.write(EEPROM_ADR_STATE,state_last_used);
                EEPROM.write(EEPROM_ADR_TUNE,channelIndex);
                TV.printPGM(10, 3,  PSTR("SAVE SETTINGS"));
                TV.printPGM(10, 5+1*MENU_Y_SIZE, PSTR("Mode:"));
                switch (state_last_used)
                        TV.printPGM(50,5+1*MENU_Y_SIZE,  PSTR("Scanner"));
                    break;
                        TV.printPGM(50,5+1*MENU_Y_SIZE,  PSTR("Manual"));
                    break;
                        TV.printPGM(50,5+1*MENU_Y_SIZE,  PSTR("Search"));
                    break;
                        TV.printPGM(50,5+1*MENU_Y_SIZE,  PSTR("Switch"));
                    break;
                TV.printPGM(10, 5+2*MENU_Y_SIZE, PSTR("Band:"));
                // print band
                if(channelIndex > 31)
                    TV.printPGM(50,5+2*MENU_Y_SIZE,  PSTR("C/Race   "));
                else if(channelIndex > 23)
                    TV.printPGM(50,5+2*MENU_Y_SIZE,  PSTR("F/Airwave"));
                else if (channelIndex > 15)
                    TV.printPGM(50,5+2*MENU_Y_SIZE,  PSTR("E        "));
                else if (channelIndex > 7)
                    TV.printPGM(50,5+2*MENU_Y_SIZE,  PSTR("B        "));
                else
                    TV.printPGM(50,5+2*MENU_Y_SIZE,  PSTR("A        "));
                TV.printPGM(10, 5+3*MENU_Y_SIZE, PSTR("Chan:"));
                uint8_t active_channel = channelIndex%CHANNEL_BAND_SIZE+1; // get channel inside band
                TV.print(50,5+3*MENU_Y_SIZE,active_channel,DEC);
                TV.printPGM(10, 5+4*MENU_Y_SIZE, PSTR("FREQ:     GHz"));
                TV.print(50,5+4*MENU_Y_SIZE, pgm_read_word_near(channelFreqTable + channelIndex));
                TV.printPGM(10, 5+5*MENU_Y_SIZE, PSTR("--- SAVED ---"));
                uint8_t loop=0;
                for (loop=0;loop<5;loop++)
                    beep(100); // beep
                    delay(100);
                delay(1000);
                TV.printPGM(10, 14+5*MENU_Y_SIZE,     PSTR("Hold MODE to enter RSSI setup"));
                delay(1000);
                delay(1000);
                if (digitalRead(buttonMode) == LOW) // to RSSI setup
                    TV.printPGM(10, 14+5*MENU_Y_SIZE, PSTR("ENTERING RSSI SETUP ......   " ));
                    uint8_t loop=0;
                    for (loop=0;loop<10;loop++)
                        #define RSSI_SETUP_BEEP 25
                        beep(RSSI_SETUP_BEEP); // beep & debounce
                        delay(RSSI_SETUP_BEEP); // debounce
                    state=STATE_RSSI_SETUP;
                        // wait for release
                else
                    TV.printPGM(10, 14+5*MENU_Y_SIZE, PSTR("                             "));
                    delay(1000);
                    state=state_last_used; // return to saved function
                    force_menu_redraw=1; // we change the state twice, must force redraw of menu
            break;
        } // end switch
        last_state=state;
    /*   Processing depending of state   */
    /*   Processing MANUAL MODE / SEEK MODE  */
    if(state == STATE_MANUAL || state == STATE_SEEK || state == STATE_SWITCH)
        if(state == STATE_MANUAL) // MANUAL MODE
            // handling of keys
            if( digitalRead(buttonSeek) == LOW)        // channel UP
                channelIndex++;
                if (channelIndex > CHANNEL_MAX_INDEX)
                    channelIndex = CHANNEL_MIN_INDEX;
            if( digitalRead(buttonDown) == LOW) // channel DOWN
                channelIndex--;
                if (channelIndex > CHANNEL_MAX_INDEX) // negative overflow
                    channelIndex = CHANNEL_MAX_INDEX;
        if(state == STATE_SWITCH) // SWITCH MODE
            // read band DIP switch (invert since switch pulls to gnd)
            uint8_t dip_band= (((digitalRead(dip_band1)<<1) | digitalRead(dip_band0)) ^0x3);
            // read channel DIP switch (invert since switch pulls to gnd)
            uint8_t dip_channel = (((digitalRead(dip_ch2)<<2) | ((digitalRead(dip_ch1))<<1) | (digitalRead(dip_ch0))) ^0x7);
            if((dip_band != last_dip_band) || (dip_channel != last_dip_channel)) // check for changes to avoid unrequred tuning
                last_dip_band=dip_band;
                last_dip_channel=dip_channel;
                // caclulate index of channel in 4x8 array
                channelIndex=CHANNEL_BAND_SIZE*last_dip_band + last_dip_channel;
        // display refresh handler
        if(update_frequency_view) // only updated on changes
            // show current used channel of bank
                TV.printPGM(50,TV_Y_OFFSET+1*TV_Y_GRID,  PSTR("C/Race   "));
                TV.printPGM(50,TV_Y_OFFSET+1*TV_Y_GRID,  PSTR("F/Airwave"));
                TV.printPGM(50,TV_Y_OFFSET+1*TV_Y_GRID,  PSTR("E        "));
                TV.printPGM(50,TV_Y_OFFSET+1*TV_Y_GRID,  PSTR("B        "));
            else
                TV.printPGM(50,TV_Y_OFFSET+1*TV_Y_GRID,  PSTR("A        "));
            // show channel inside band
            uint8_t active_channel = channelIndex%CHANNEL_BAND_SIZE; // get channel inside band
            if(!first_channel_marker)
                // clear last marker
                TV.draw_rect(last_active_channel*16+2 ,TV_Y_OFFSET-2+2*TV_Y_GRID,12,12,  BLACK, INVERT); // mark current channel
            first_channel_marker=0;
            // set new marker
            TV.draw_rect(active_channel*16+2 ,TV_Y_OFFSET-2+2*TV_Y_GRID,12,12,  WHITE, INVERT); // mark current channel
            last_active_channel=active_channel;
            // show frequence
            TV.print(50,TV_Y_OFFSET+3*TV_Y_GRID, pgm_read_word_near(channelFreqTable + channelIndex));
        // show signal strength
        #define RSSI_BAR_SIZE 100
        rssi_scaled=map(rssi, 1, 100, 1, RSSI_BAR_SIZE);
        // clear last bar
        TV.draw_rect(25, TV_Y_OFFSET+4*TV_Y_GRID, RSSI_BAR_SIZE,4 , BLACK, BLACK);
        //  draw new bar
        TV.draw_rect(25, TV_Y_OFFSET+4*TV_Y_GRID, rssi_scaled, 4 , WHITE, WHITE);
        // print bar for spectrum
        channel=channel_from_index(channelIndex); // get 0...39 index depending of current channel
        wait_rssi_ready();
        #define SCANNER_BAR_MINI_SIZE 14
        rssi = readRSSI();
        rssi_scaled=map(rssi, 1, 100, 1, SCANNER_BAR_MINI_SIZE);
        hight = (TV_ROWS - TV_SCANNER_OFFSET - rssi_scaled);
        // clear last bar
        TV.draw_rect((channel * 3), (TV_ROWS - TV_SCANNER_OFFSET - SCANNER_BAR_MINI_SIZE), 3, SCANNER_BAR_MINI_SIZE , BLACK, BLACK);
        //  draw new bar
        TV.draw_rect((channel * 3), hight, 3, rssi_scaled , WHITE, WHITE);
        // set marker in spectrum to show current scanned channel
        if(channel < CHANNEL_MAX_INDEX)
            // clear last square
            TV.draw_rect((last_maker_pos * 3)+2, (TV_ROWS - TV_SCANNER_OFFSET + 8),SCANNER_MARKER_SIZE,SCANNER_MARKER_SIZE,  BLACK, BLACK);
            // draw next
            TV.draw_rect((channel * 3)+2, (TV_ROWS - TV_SCANNER_OFFSET + 8),SCANNER_MARKER_SIZE,SCANNER_MARKER_SIZE,  WHITE, WHITE);
            last_maker_pos=channel;
        else
          //  No action on last position to keep frame intact
        // handling for seek mode after screen and RSSI has been fully processed
        if(state == STATE_SEEK) //
        { // SEEK MODE
            if(!seek_found) // search if not found
                if ((!force_seek) && (rssi > RSSI_SEEK_TRESHOLD)) // check for found channel
                    seek_found=1;
                    // beep twice as notice of lock
                    beep(100);
                    delay(100);
                    beep(100);
                else
                { // seeking itself
                    force_seek=0;
                    // next channel
                    if (channel < CHANNEL_MAX)
                        channel++;
                    } else {
            else
            { // seek was successful
                TV.printPGM(10, TV_Y_OFFSET,  PSTR("AUTO MODE LOCK"));
                if (digitalRead(buttonSeek) == LOW) // restart seek if key pressed
                    force_seek=1;
                    seek_found=0;
        TV.delay_frame(1); // clean redraw
    /*   Processing SCAN MODE   */
    else if (state == STATE_SCAN || state == STATE_RSSI_SETUP)
        // force tune on new scan start to get right RSSI value
        if(scan_start)
            scan_start=0;
            setChannelModule(channelIndex);
            last_channel_index=channelIndex;
            // keep time of tune to make sure that RSSI is stable when required
            time_of_tune=millis();
        // channel marker
            // draw next
        else
        wait_rssi_ready();
        // value must be ready
        rssi = readRSSI();
        rssi_scaled=map(rssi, 1, 100, 5, SCANNER_BAR_SIZE);
        // clear last bar
        TV.draw_rect((channel * 3), (TV_ROWS - TV_SCANNER_OFFSET - SCANNER_BAR_SIZE), 2, SCANNER_BAR_SIZE , BLACK, BLACK);
        //  draw new bar
        TV.draw_rect((channel * 3), hight, 2, rssi_scaled , WHITE, WHITE);
        // print channelname
        if(state == STATE_SCAN)
            if (rssi > RSSI_SEEK_TRESHOLD)
                TV.draw_rect(writePos, SCANNER_LIST_Y_POS, 20, 6,  BLACK, BLACK);
                TV.print(writePos, SCANNER_LIST_Y_POS, pgm_read_byte_near(channelNames + channelIndex), HEX);
                TV.print(writePos+10, SCANNER_LIST_Y_POS, pgm_read_word_near(channelFreqTable + channelIndex));
                writePos += 30;
                // mark bar
                TV.print((channel * 3) - 3, hight - 5, pgm_read_byte_near(channelNames + channelIndex), HEX);
        // next channel
            channel++;
        } else {
            if(state == STATE_RSSI_SETUP)
                if(!rssi_setup_run--)
                    // setup done
                    rssi_min=rssi_setup_min;
                    rssi_max=rssi_setup_max;
                    // save 16 bit
                    EEPROM.write(EEPROM_ADR_RSSI_MIN_L,(rssi_min & 0xff));
                    EEPROM.write(EEPROM_ADR_RSSI_MIN_H,(rssi_min >> 8));
                    // save 16 bit
                    EEPROM.write(EEPROM_ADR_RSSI_MAX_L,(rssi_max & 0xff));
                    EEPROM.write(EEPROM_ADR_RSSI_MAX_H,(rssi_max >> 8));
                    beep(1000);
        // new scan possible by press scan
        if (digitalRead(buttonSeek) == LOW) // force new full new scan
            last_state=255; // force redraw by fake state change ;-)
            scan_start=1;
        // update index after channel change
    /*   General house keeping   */
    if(last_channel_index != channelIndex)         // tune channel on demand
        // give 3 beeps when tuned to give feedback of correct start
        if(first_tune)
            first_tune=0;
            #define UP_BEEP 100
            beep(UP_BEEP);
            delay(UP_BEEP);
            beep(UP_BEEP);
            delay(UP_BEEP);
            beep(UP_BEEP);
    //rssi = readRSSI();
/*   SUB ROUTINES  */
void beep(uint16_t time)
    digitalWrite(buzzer, LOW);
    delay(time);
uint8_t channel_from_index(uint8_t channelIndex)
    uint8_t loop=0;
    uint8_t channel=0;
    for (loop=0;loop<=CHANNEL_MAX;loop++)
        if(pgm_read_byte_near(channelList + loop) == channelIndex)
            channel=loop;
            break;
    return (channel);
void wait_rssi_ready()
    // CHECK FOR MINIMUM DELAY
    // check if RSSI is stable after tune by checking the time
    uint16_t tune_time = millis()-time_of_tune;
    // module need >20ms to tune.
    // 30 ms will to a 32 channel scan in 1 second.
    #define MIN_TUNE_TIME 30
    if(tune_time < MIN_TUNE_TIME)
        // wait until tune time is full filled
        delay(MIN_TUNE_TIME-tune_time);
uint16_t readRSSI()
    uint16_t rssi = 0;
    for (uint8_t i = 0; i < 10; i++)
        rssi += analogRead(rssiPin);
    rssi=rssi/10; // average
    // special case for RSSI setup
    if(state==STATE_RSSI_SETUP)
    { // RSSI setup
        if(rssi < rssi_setup_min)
            rssi_setup_min=rssi;
            TV.print(50, SCANNER_LIST_Y_POS, "   ");
            TV.print(50, SCANNER_LIST_Y_POS, rssi_setup_min , DEC);
        if(rssi > rssi_setup_max)
            rssi_setup_max=rssi;
        TV.print(110, SCANNER_LIST_Y_POS, "   ");
        TV.print(110, SCANNER_LIST_Y_POS, rssi_setup_max , DEC);
        // dump current values
    //TV.print(50, SCANNER_LIST_Y_POS-10, rssi_min , DEC);
    //TV.print(110, SCANNER_LIST_Y_POS-10, rssi_max , DEC);
    // scale AD RSSI Valaues to 1-100%
    //#define RSSI_DEBUG
    // Filter glitches
    #ifdef RSSI_DEBUG
        TV.print(1,20, "RAW:             ");
        TV.print(30,20, rssi, DEC);
    #endif
    rssi = constrain(rssi, rssi_min, rssi_max);    //original 90---250
    rssi=rssi-rssi_min; // set zero point (value 0...160)
    rssi = map(rssi, 0, rssi_max-rssi_min , 1, 100);   // scale from 1..100%
    #ifdef RSSI_DEBUG
        TV.print(1,40, "SCALED:           ");
        TV.print(50,40, rssi, DEC);
    #endif
    return (rssi);
// Private function: from http://arduino.cc/playground/Code/AvailableMemory
int freeRam () {
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
void setChannelModule(uint8_t channel)
  uint8_t i;
  uint16_t channelData;
  //channelData = pgm_read_word(&channelTable[channel]);
  //channelData = channelTable[channel];
  channelData = pgm_read_word_near(channelTable + channel);
  // bit bash out 25 bits of data
  // Order: A0-3, !R/W, D0-D19
  // A0=0, A1=0, A2=0, A3=1, RW=0, D0-19=0
  SERIAL_ENABLE_HIGH();
  delayMicroseconds(1);
  //delay(2);
  SERIAL_ENABLE_LOW();
  SERIAL_SENDBIT0();
  SERIAL_SENDBIT0();
  SERIAL_SENDBIT0();
  SERIAL_SENDBIT1();
  SERIAL_SENDBIT0();
  // remaining zeros
  for (i = 20; i > 0; i--)
    SERIAL_SENDBIT0();
  // Clock the data in
  //delay(2);
  // Second is the channel data from the lookup table
  // 20 bytes of register data are sent, but the MSB 4 bits are zeros
  // register address = 0x1, write, data0-15=channelData data15-19=0x0
  // Register 0x1
  SERIAL_SENDBIT1();
  SERIAL_SENDBIT0();
  SERIAL_SENDBIT0();
  SERIAL_SENDBIT0();
  // Write to register
  SERIAL_SENDBIT1();
  // D0-D15
  //   note: loop runs backwards as more efficent on AVR
  for (i = 16; i > 0; i--)
    // Is bit high or low?
    if (channelData & 0x1)
      SERIAL_SENDBIT1();
    else
      SERIAL_SENDBIT0();
    // Shift bits along to check the next one
    channelData >>= 1;
  // Remaining D16-D19
  for (i = 4; i > 0; i--)
    SERIAL_SENDBIT0();
  // Finished clocking data in
  //delay(2);
  digitalWrite(slaveSelectPin, LOW);
  digitalWrite(spiClockPin, LOW);
  digitalWrite(spiDataPin, LOW);
void SERIAL_SENDBIT1()
  digitalWrite(spiDataPin, HIGH);
  digitalWrite(spiClockPin, HIGH);
void SERIAL_SENDBIT0()
void SERIAL_ENABLE_LOW()
void SERIAL_ENABLE_HIGH()
  digitalWrite(slaveSelectPin, HIGH);
So macht auch der Marker im Scan Mode was er soll, der Johannes hat da eine kleine Änderung übersehen.
(Off Topic Rant: WER HAT DIESE DRECKS ARDUINO IDE ERFUNDEN?!?)
Gruß, Olli
Ich bins mal wieder :)
Ich muss zugeben das ich kurz vorm platzen bin, klingt eklig, ist aber so.
Und zwar habe ich 2 mal versucht von github aus die ino, was ja nur text ist zu kompilieren....
Code:
sketch_jul06a.ino:38:22: error: settings.h: No such file or directory
sketch_jul06a:102: error: 'useReceiverA' was not declared in this scope
sketch_jul06a:107: error: 'RSSI_SEEK_TRESHOLD' was not declared in this scope
sketch_jul06a:109: error: 'START_STATE' was not declared in this scope
sketch_jul06a:110: error: 'START_STATE' was not declared in this scope
sketch_jul06a:111: error: 'START_STATE' was not declared in this scope
sketch_jul06a:129: error: 'RSSI_MIN_VAL' was not declared in this scope
sketch_jul06a:130: error: 'RSSI_MAX_VAL' was not declared in this scope
sketch_jul06a:131: error: 'RSSI_MIN_VAL' was not declared in this scope
sketch_jul06a:132: error: 'RSSI_MAX_VAL' was not declared in this scope
sketch_jul06a.ino: In function 'void setup()':
sketch_jul06a:150: error: 'led' was not declared in this scope
sketch_jul06a:153: error: 'buzzer' was not declared in this scope
sketch_jul06a:156: error: 'buttonUp' was not declared in this scope
sketch_jul06a:158: error: 'buttonMode' was not declared in this scope
sketch_jul06a:161: error: 'buttonDown' was not declared in this scope
sketch_jul06a:163: error: 'buttonSave' was not declared in this scope
sketch_jul06a:166: error: 'receiverA_led' was not declared in this scope
sketch_jul06a:170: error: 'useReceiverA' was not declared in this scope
sketch_jul06a:172: error: 'slaveSelectPin' was not declared in this scope
sketch_jul06a:173: error: 'spiDataPin' was not declared in this scope
sketch_jul06a:174: error: 'spiClockPin' was not declared in this scope
sketch_jul06a:177: error: 'EEPROM_ADR_STATE' was not declared in this scope
sketch_jul06a:181: error: 'START_STATE' was not declared in this scope
sketch_jul06a:182: error: 'EEPROM_ADR_TUNE' was not declared in this scope
sketch_jul06a:182: error: 'CHANNEL_MIN_INDEX' was not declared in this scope
sketch_jul06a:183: error: 'EEPROM_ADR_BEEP' was not declared in this scope
sketch_jul06a:184: error: 'EEPROM_ADR_ORDERBY' was not declared in this scope
sketch_jul06a:186: error: 'EEPROM_ADR_RSSI_MIN_A_L' was not declared in this scope
sketch_jul06a:186: error: 'RSSI_MIN_VAL' was not declared in this scope
sketch_jul06a:187: error: 'EEPROM_ADR_RSSI_MIN_A_H' was not declared in this scope
sketch_jul06a:189: error: 'EEPROM_ADR_RSSI_MAX_A_L' was not declared in this scope
sketch_jul06a:189: error: 'RSSI_MAX_VAL' was not declared in this scope
sketch_jul06a:190: error: 'EEPROM_ADR_RSSI_MAX_A_H' was not declared in this scope
sketch_jul06a:193: error: 'CALL_SIGN' was not declared in this scope
sketch_jul06a:195: error: 'EEPROM_ADR_CALLSIGN' was not declared in this scope
sketch_jul06a:214: error: 'EEPROM_ADR_TUNE' was not declared in this scope
sketch_jul06a:220: error: 'EEPROM_ADR_BEEP' was not declared in this scope
sketch_jul06a:221: error: 'EEPROM_ADR_ORDERBY' was not declared in this scope
sketch_jul06a:225: error: 'EEPROM_ADR_CALLSIGN' was not declared in this scope
sketch_jul06a:228: error: 'EEPROM_ADR_RSSI_MIN_A_H' was not declared in this scope
sketch_jul06a:228: error: 'EEPROM_ADR_RSSI_MIN_A_L' was not declared in this scope
sketch_jul06a:229: error: 'EEPROM_ADR_RSSI_MAX_A_H' was not declared in this scope
sketch_jul06a:229: error: 'EEPROM_ADR_RSSI_MAX_A_L' was not declared in this scope
sketch_jul06a.ino: In function 'void loop()':
sketch_jul06a:271: error: 'buttonMode' was not declared in this scope
sketch_jul06a:275: error: 'KEY_DEBOUNCE' was not declared in this scope
sketch_jul06a:291: error: 'STATE_SEEK_FOUND' was not declared in this scope
sketch_jul06a:293: error: 'STATE_SEEK' was not declared in this scope
sketch_jul06a:310: error: 'STATE_SAVE' was not declared in this scope
sketch_jul06a:316: error: 'STATE_SEEK' was not declared in this scope
sketch_jul06a:321: error: 'STATE_SCAN' was not declared in this scope
sketch_jul06a:325: error: 'STATE_MANUAL' was not declared in this scope
sketch_jul06a:342: error: 'STATE_SETUP_MENU' was not declared in this scope
sketch_jul06a:349: error: 'buttonUp' was not declared in this scope
sketch_jul06a:349: error: 'buttonDown' was not declared in this scope
sketch_jul06a:354: error: 'buttonUp' was not declared in this scope
sketch_jul06a:354: error: 'buttonDown' was not declared in this scope
sketch_jul06a:374: error: 'buttonUp' was not declared in this scope
sketch_jul06a:382: error: 'buttonDown' was not declared in this scope
sketch_jul06a:410: error: 'buttonSave' was not declared in this scope
sketch_jul06a:412: error: 'STATE_SAVE' was not declared in this scope
sketch_jul06a:428: error: 'STATE_SCAN' was not declared in this scope
sketch_jul06a:430: error: 'STATE_RSSI_SETUP' was not declared in this scope
sketch_jul06a:437: error: 'RSSI_MAX_VAL' was not declared in this scope
sketch_jul06a:438: error: 'RSSI_MIN_VAL' was not declared in this scope
sketch_jul06a:445: error: 'RSSI_SETUP_RUN' was not declared in this scope
sketch_jul06a:449: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:456: error: 'STATE_SEEK' was not declared in this scope
sketch_jul06a:457: error: 'RSSI_SEEK_TRESHOLD' was not declared in this scope
sketch_jul06a:460: error: 'STATE_MANUAL' was not declared in this scope
sketch_jul06a:473: error: 'EEPROM_ADR_TUNE' was not declared in this scope
sketch_jul06a:482: error: 'STATE_SETUP_MENU' was not declared in this scope
sketch_jul06a:485: error: 'STATE_SAVE' was not declared in this scope
sketch_jul06a:486: error: 'EEPROM_ADR_TUNE' was not declared in this scope
sketch_jul06a:487: error: 'EEPROM_ADR_STATE' was not declared in this scope
sketch_jul06a:488: error: 'EEPROM_ADR_BEEP' was not declared in this scope
sketch_jul06a:489: error: 'EEPROM_ADR_ORDERBY' was not declared in this scope
sketch_jul06a:492: error: 'EEPROM_ADR_CALLSIGN' was not declared in this scope
sketch_jul06a:517: error: 'STATE_SCREEN_SAVER' was not declared in this scope
sketch_jul06a:533: error: 'buttonMode' was not declared in this scope
sketch_jul06a:533: error: 'buttonUp' was not declared in this scope
sketch_jul06a:533: error: 'buttonDown' was not declared in this scope
sketch_jul06a:584: error: 'STATE_MANUAL' was not declared in this scope
sketch_jul06a:584: error: 'STATE_SEEK' was not declared in this scope
sketch_jul06a:601: error: 'buttonUp' was not declared in this scope
sketch_jul06a:605: error: 'KEY_DEBOUNCE' was not declared in this scope
sketch_jul06a:608: error: 'CHANNEL_MAX' was not declared in this scope
sketch_jul06a:608: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:609: error: 'CHANNEL_MAX_INDEX' was not declared in this scope
sketch_jul06a:611: error: 'CHANNEL_MIN_INDEX' was not declared in this scope
sketch_jul06a:614: error: 'buttonDown' was not declared in this scope
sketch_jul06a:618: error: 'KEY_DEBOUNCE' was not declared in this scope
sketch_jul06a:621: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:621: error: 'CHANNEL_MAX' was not declared in this scope
sketch_jul06a:622: error: 'CHANNEL_MAX_INDEX' was not declared in this scope
sketch_jul06a:639: error: 'RSSI_SEEK_TRESHOLD' was not declared in this scope
sketch_jul06a:657: error: 'CHANNEL_MAX' was not declared in this scope
sketch_jul06a:661: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:664: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:679: error: 'buttonUp' was not declared in this scope
sketch_jul06a:679: error: 'buttonDown' was not declared in this scope
sketch_jul06a:688: error: 'KEY_DEBOUNCE' was not declared in this scope
sketch_jul06a:697: error: 'SCREENSAVER_TIMEOUT' was not declared in this scope
sketch_jul06a:698: error: 'STATE_SCREEN_SAVER' was not declared in this scope
sketch_jul06a:706: error: 'STATE_SCAN' was not declared in this scope
sketch_jul06a:706: error: 'STATE_RSSI_SETUP' was not declared in this scope
sketch_jul06a:723: error: 'RSSI_SEEK_TRESHOLD' was not declared in this scope
sketch_jul06a:737: error: 'CHANNEL_MAX' was not declared in this scope
sketch_jul06a:743: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:752: error: 'RSSI_MAX_VAL' was not declared in this scope
sketch_jul06a:755: error: 'EEPROM_ADR_RSSI_MIN_A_L' was not declared in this scope
sketch_jul06a:756: error: 'EEPROM_ADR_RSSI_MIN_A_H' was not declared in this scope
sketch_jul06a:758: error: 'EEPROM_ADR_RSSI_MAX_A_L' was not declared in this scope
sketch_jul06a:759: error: 'EEPROM_ADR_RSSI_MAX_A_H' was not declared in this scope
sketch_jul06a:777: error: 'EEPROM_ADR_STATE' was not declared in this scope
sketch_jul06a:783: error: 'buttonUp' was not declared in this scope
sketch_jul06a:786: error: 'KEY_DEBOUNCE' was not declared in this scope
sketch_jul06a:788: error: 'CHANNEL_MIN' was not declared in this scope
sketch_jul06a:797: error: 'STATE_SETUP_MENU' was not declared in this scope
sketch_jul06a:807: error: 'buttonMode' was not declared in this scope
sketch_jul06a:807: error: 'buttonUp' was not declared in this scope
sketch_jul06a:807: error: 'buttonDown' was not declared in this scope
sketch_jul06a:817: error: 'buttonMode' was not declared in this scope
sketch_jul06a:842: error: 'STATE_RSSI_SETUP' was not declared in this scope
sketch_jul06a:846: error: 'STATE_SAVE' was not declared in this scope
sketch_jul06a:850: error: 'buttonUp' was not declared in this scope
sketch_jul06a:865: error: 'buttonDown' was not declared in this scope
sketch_jul06a:892: error: 'buttonMode' was not declared in this scope
sketch_jul06a:892: error: 'buttonUp' was not declared in this scope
sketch_jul06a:892: error: 'buttonDown' was not declared in this scope
sketch_jul06a.ino: In function 'void beep(uint16_t)':
sketch_jul06a:927: error: 'led' was not declared in this scope
sketch_jul06a:929: error: 'buzzer' was not declared in this scope
sketch_jul06a:933: error: 'buzzer' was not declared in this scope
sketch_jul06a.ino: In function 'uint8_t channel_from_index(uint8_t)':
sketch_jul06a:940: error: 'CHANNEL_MAX' was not declared in this scope
sketch_jul06a.ino: In function 'void wait_rssi_ready()':
sketch_jul06a:956: error: 'MIN_TUNE_TIME' was not declared in this scope
sketch_jul06a.ino: In function 'uint16_t readRSSI()':
sketch_jul06a:977: error: 'RSSI_READS' was not declared in this scope
sketch_jul06a:979: error: 'rssiPinA' was not declared in this scope
sketch_jul06a:985: error: 'RSSI_READS' was not declared in this scope
sketch_jul06a:991: error: 'STATE_RSSI_SETUP' was not declared in this scope
sketch_jul06a.ino: In function 'void setReceiver(uint8_t)':
sketch_jul06a:1084: error: 'receiverA_led' was not declared in this scope
sketch_jul06a.ino: In function 'void setChannelModule(uint8_t)':
sketch_jul06a:1187: error: 'slaveSelectPin' was not declared in this scope
sketch_jul06a:1188: error: 'spiClockPin' was not declared in this scope
sketch_jul06a:1189: error: 'spiDataPin' was not declared in this scope
sketch_jul06a.ino: In function 'void SERIAL_SENDBIT1()':
sketch_jul06a:1195: error: 'spiClockPin' was not declared in this scope
sketch_jul06a:1198: error: 'spiDataPin' was not declared in this scope
sketch_jul06a.ino: In function 'void SERIAL_SENDBIT0()':
sketch_jul06a:1209: error: 'spiClockPin' was not declared in this scope
sketch_jul06a:1212: error: 'spiDataPin' was not declared in this scope
sketch_jul06a.ino: In function 'void SERIAL_ENABLE_LOW()':
sketch_jul06a:1224: error: 'slaveSelectPin' was not declared in this scope
sketch_jul06a.ino: In function 'void SERIAL_ENABLE_HIGH()':
sketch_jul06a:1231: error: 'slaveSelectPin' was not declared in this scope
Watt mach ich denn wieder falsch ? :(
apropo:
Möchte diesmal das Diversity ohne oled (dafür mit tvout) haben.
Gibt's da eigentlich eine flyinglemon diversity ähnliche variante des tvOut + Oled wo man für einige sekunden kanal, rssi wert und co eingeblendet bekommt ?
MarenB
Runter kommen sie immer!
Sieht aus, als hättest du nur eine Datei kompilieren wollen?!
Das Programm ist auf mehrere Dateien verteilt, deshalb empfiehlt es sich, von github immer alles als ZIP herunterzuladen.
Viele Grüße
Maren
Oh man, total übersehen.
Danke dir
Habe jetzt die zip geladen aber es geht nicht.
Adafruit_SSD1306 does not name a type und der orangene bereich ist rand voll mit "fehlern"
Dann kann ich die Libarys nicht importieren da er ständig meldet "nur zahlen und buchstaben...." Selbst wenn ich die libarys auf den desktop ziehe.
Es geht auch nicht wenn ich ndie komplette zip nehme, ich kapiere das nicht
Es kommt auch 4 mal hintereinander diese meldung im anhang, auch nach einem neustart fl.jpg
MarenB
Nicht importieren!
Einfach entpacken und dann die *.ino in der Arduino-IDE öffnen, die include-Dateien werden dann mitgeladen. Wenn dann noch ein Fehler kommt, fehlt dir ggf. eine Library.
Code:
oled_128x64_adafruit_screens.cpp:56:4: error: #error ("Screen size incorrect, please fix Adafruit_SSD1306.h!");
oled_128x64_adafruit_screens.cpp:54: error: 'Adafruit_SSD1306' does not name a type
oled_128x64_adafruit_screens.cpp: In member function 'char screens::begin(const char*)':
oled_128x64_adafruit_screens.cpp:72: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:72: error: 'SSD1306_SWITCHCAPVCC' was not declared in this scope
oled_128x64_adafruit_screens.cpp:82: error: 'delay' was not declared in this scope
oled_128x64_adafruit_screens.cpp:87: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:88: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:105: error: 'A7' was not declared in this scope
oled_128x64_adafruit_screens.cpp:105: error: 'analogRead' was not declared in this scope
oled_128x64_adafruit_screens.cpp:112: error: 'strlen' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::reset()':
oled_128x64_adafruit_screens.cpp:121: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:124: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::flip()':
oled_128x64_adafruit_screens.cpp:128: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::drawTitleBox(const char*)':
oled_128x64_adafruit_screens.cpp:132: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:132: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:136: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:138: error: 'strlen' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::mainMenu(uint8_t)':
oled_128x64_adafruit_screens.cpp:147: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:147: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:149: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:160: error: 'A7' was not declared in this scope
oled_128x64_adafruit_screens.cpp:160: error: 'analogRead' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::seekMode(uint8_t)':
oled_128x64_adafruit_screens.cpp:185: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:185: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::updateSeekMode(uint8_t, uint8_t, uint8_t, uint8_t, uint16_t, uint8_t, bool)':
oled_128x64_adafruit_screens.cpp:218: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:218: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:218: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:256: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:256: error: 'map' was not declared in this scope
oled_128x64_adafruit_screens.cpp:258: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:259: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::bandScanMode(uint8_t)':
oled_128x64_adafruit_screens.cpp:303: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:309: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:312: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:312: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::updateBandScanMode(bool, uint8_t, uint8_t, uint8_t, uint16_t, uint16_t, uint16_t)':
oled_128x64_adafruit_screens.cpp:327: error: 'map' was not declared in this scope
oled_128x64_adafruit_screens.cpp:328: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:331: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:332: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:341: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:341: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:343: error: 'HEX' was not declared in this scope
oled_128x64_adafruit_screens.cpp:357: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:357: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:360: error: 'DEC' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::screenSaver(uint8_t, uint8_t, uint16_t, const char*)':
oled_128x64_adafruit_screens.cpp:377: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:378: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:380: error: 'HEX' was not declared in this scope
oled_128x64_adafruit_screens.cpp:390: error: 'A7' was not declared in this scope
oled_128x64_adafruit_screens.cpp:390: error: 'analogRead' was not declared in this scope
oled_128x64_adafruit_screens.cpp:403: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::updateScreenSaver(char, uint8_t, uint8_t, uint8_t)':
oled_128x64_adafruit_screens.cpp:421: error: 'A7' was not declared in this scope
oled_128x64_adafruit_screens.cpp:421: error: 'analogRead' was not declared in this scope
oled_128x64_adafruit_screens.cpp:424: error: 'map' was not declared in this scope
oled_128x64_adafruit_screens.cpp:425: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:425: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:428: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:433: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:441: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:446: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:450: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:450: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:451: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:455: error: 'map' was not declared in this scope
oled_128x64_adafruit_screens.cpp:471: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:471: error: 'millis' was not declared in this scope
oled_128x64_adafruit_screens.cpp:471: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:471: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:476: error: 'A7' was not declared in this scope
oled_128x64_adafruit_screens.cpp:476: error: 'analogRead' was not declared in this scope
oled_128x64_adafruit_screens.cpp:477: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:477: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:480: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::diversity(uint8_t)':
oled_128x64_adafruit_screens.cpp:490: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:490: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:492: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::updateDiversity(char, uint8_t, uint8_t)':
oled_128x64_adafruit_screens.cpp:515: error: 'map' was not declared in this scope
oled_128x64_adafruit_screens.cpp:517: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:517: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:520: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:525: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:533: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:538: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::updateSetupMenu(uint8_t, bool, bool, const char*, char)':
oled_128x64_adafruit_screens.cpp:551: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:551: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:553: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::save(uint8_t, uint8_t, uint16_t, const char*)':
oled_128x64_adafruit_screens.cpp:603: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:603: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:649: error: 'DEC' was not declared in this scope
oled_128x64_adafruit_screens.cpp: In member function 'void screens::updateSave(const char*)':
oled_128x64_adafruit_screens.cpp:666: error: 'display' was not declared in this scope
oled_128x64_adafruit_screens.cpp:666: error: 'WHITE' was not declared in this scope
oled_128x64_adafruit_screens.cpp:666: error: 'BLACK' was not declared in this scope
oled_128x64_adafruit_screens.cpp:667: error: 'strlen' was not declared in this scope
einfach die *.ino geöffnet und auf überprüfen geklickt...
Arduino is für mich n Buch mit 17 Siegeln
Ich habe keine ahnung wie man da was deaktiviert :D Wie gesagt, Arduino ist für mich leider eine qual
Und eigentlich wollte ich die version ohne oled
MarenB
also mit TV-out?
in dem Fall musst du in der settings.h das hier
Code:
// Choose the display you will be using
// you will also have to uncomment the includes in the main project.
//#define TVOUT_SCREENS
#define OLED_128x64_ADAFRUIT_SCREENS
Gegen das hier tauschen:
Code:
//#define OLED_128x64_ADAFRUIT_SCREENS
und in der *.ino:
Code:
// uncomment depending on the display you are using.
// this is an issue with the arduino preprocessor
#ifdef TVOUT_SCREENS
//    #include <TVout.h>
//    #include <fontALL.h>
#endif
#ifdef OLED_128x64_ADAFRUIT_SCREENS
	#ifdef SH1106
		#include <Adafruit_SH1106.h>
	#else
		#include <Adafruit_SSD1306.h>
	#endif
    #include <Adafruit_GFX.h>
    #include <Wire.h>
    #include <SPI.h>
#endif
#ifdef OLED_128x64_U8G_SCREENS
//    #include <U8glib.h>
#endif
gegen
#include <TVout.h>
#endif
#ifdef SH1106
// #include <Adafruit_SH1106.h>
#else
// #include <Adafruit_SSD1306.h>
#endif
//#include <Adafruit_GFX.h>
//#include <Wire.h>
//#include <SPI.h>
#endif
#endif
du brauchst dann aber die TV-out Library, er wird dann ja versuchen, die TVout.h und die fontALL.h einzubinden.
Die TV out libary habe ich noch vom rx5808 pro.
Ich kann aber die stelle in der *.ino nicht finden, geschweige denn das ich irgendwas mit ino zur verfügung hätte.
Warum die ide jetzt meckert das die elendige Tvout libary nicht da wäre weis ich auch nicht, es ist doch in der libary drin !
Echt zum ausflippen sowas
Danke MarenB
Habe mir alle fenster noch mal durch gelesen und die stelle gefunden in der ino :)
