bezüglich den Funktionskombinationen steht in der eng. Dokumentation Seite 31 folgendes:
PH und Height Lock zusammen klappt bei mir ohne Probleme - siehe obiges Video.
- ich werde morgen mal PH ohne Height Lock testen...
1) each row is one function: you can select according to the channel of your remote control and switch position.
For example: If you only want to set low-bit switch of 5-channel as autostability function,
then you just ticked box on the first row and first column.
At this time, only low-bit switch of 5 channel turn on, it is provided with autostability function,
if you do not use this low-bit,it does not have autostability function.
You can also check high, medium and low grade of 5,6-channel at the same time,
in this way, use anyone of the six stalls have autostability function.
If no ticked on this row, it means that no matter which switch position of which channel ,it do not have the custom funtions.
Due to the function needs: "autostability" and "3D stunt", "Head lock" and "CareFree " can NOT be defined in the same switch position of the same channel, so that the same column can not be selected at the same time.
For example, you can not define the low switch position of 5-channel as “Self-stability” and “3D special effects” functions at the same time.
Nor can it be defined as “Heading lock “and “Undirected CF” functions as the same.
But you can define the low-grade switch position as “Self-stability “ and define medium-grade switch position as "3D special effects".
Due to the function needs: “autolanding” must be combined with the "height lock".
Therefore, when you select the function "autolanding”, the config-tool will automatically ticked "height lock" function.
Accordingly, when you cancel the "height lock" function, the “autolanding “ function will be canceled at the same automatically.
