Endlich! OSD für DJI Naza/GPS
MisterMartini
Doch, doch, hatte ihn schon ein paar Mal auf, Neben der Naza habe ich den GR-16 verbaut und auf der anderen Seite
das Graupner GPS-Modul, welches ja dann wegfällt.
Und du meinst, dass das GPS nicht in irgendeiner Form beeinflusst wird, wenn ich die Platine direkt auf die NAZA setze?
Boarder
GPS location (Lat., Long.)......From the GPS Puck
Altitude....................................Derive d from the GPS data
Course....................................Derived from the GPS data
Speed......................................Derived from the GPS data
Virtual Horizon........................Derived from the Gimbal output
Pitch/Roll.................................Derived from the Gimbal output
Battery Voltage........................Provided by the included voltage divider or from an
.................................................A ttoPilot power sensor
Battery Current........................Provided by an AttoPilot power sensor
Battery Condition (% Remaining) Derived from the AttoPilot power sensor
Flight mode...............................Decoded from the Naza LED module connection
........Manual => Acro
........Auto => Stabilize
........GPS => Guided
........Failsafe => RTL
Distance to home....................Derived from the GPS data
Direction to home....................(OSD only) Derived from the GPS data
How it works:
A connection to the Naza GPS puck give the positioning and altitude information. Direction, speed, and distance are derived from this data.
Connections from the Naza LED module are decoded to determine the Mode.
The Naza Gimbal servo output (M1, M2) are the source for the roll and pitch data.
A provided special connection to the main battery is converted to Battery Volts.
An AttoPilot power sensor connected between the main battery and the multirotor gives battery voltage, current, and condition (% remaining).
What it can do:
The Naza data seen on the Mission Planner ground control station is nothing short of fantastic!
Not only do you see all of the above information on a very well designed GUI interface including flight path and current position, you can get realtime audio announcement of critical flight data such as altitude, ground speed, mode, and battery condition. Mission Planner can play back an automatically saved log file. The log file can be converted into a .kml file that will generate a Google Earth presentation that shows the flight path in mode annotated segments.
What it can't do:
Airframe heading is not available. Realtime gyro and accelerometer information are not available. Radio transmitter channel position and motor output levels are not available.
Transmission is one way only. Data, commands, or parameter changes can not sent from the Ground Control Station to the FBOSD. Waypoint flying is not possible. Many of the Mission Planner capabilities are not available.
MisterMartini
Wenn ich das richtig deute, werden die Daten in den Videokanal vor dem Sender eingeschleift und dann quasi im
Videobild mit übertragen, richtig?
Da braucht man keinen Audiokanal, oder?
ApoC
Moderator
#46
OSD Informationen werden immer zwischen Cam und Sender eingeschleift.
Was du meinst (Audiokanal) ist Telemetrie, die kommt bei dem Typen aber per Telemetrie Sender zum Boden. Mavlink Protokoll - und kann somit mit jeder MAV kompatiblenen Groundstationsoftware (qgroundcontrol meine ich, hat er benutzt) angezeigt werden.
MisterMartini
Das heisst also, wenn ich die Daten nur auf dem Bildschirm sehen will brauche ich keinen Audiokanal,
nur wenn ich eine Echtzeit-Auswertung am PC machen will dann ja, richtig?
ApoC
Moderator
#49
Richtig.
Die Daten des OSD werden ja auf dem Flieger ins Videosignal eingeschleift. Am Boden einfach eine Brille / Moni an den RX und Peng. ;)
Was mir am wichtigsten wäre, ist die verbrauchte Kapazität. Weiss jemand welcher Stromsensor da kompatibel ist?
Steht auch da. AttoPilot.
Koiudo
werde immer besser !
#50
Echt ne coole Sache... .das muss jetzt DJI mal ihr iOSD für die Naza auf den Markt bringen.....
Preise für das Naza OSD :
Bronze Package: $33 + shipping
GPS Lat/Long
Altitude
Course
Speed
Virtual Horizon
Pitch/Roll
Battery Voltage
Flight mode
Does NOT include a current sensor, OSD, or data modem (provide your own)
Silver Package: $49 + shipping
Everything above, plus a USB wiring harness and adapter that lets you upgrade the software on my device with any new versions that I release, free of charge. In electronics speak, this is called a FTDI adapter, and if you've got one with the correct pinout you're welcome to use your own with the cheap version of the board and I'll still make all the updates available for free.
Gold Package: $75 + shipping
Everything above, plus a MinimOSD board, which will be hardwired into my device into one neat little package. Connect your video camera to the video in plug and connect your TX to the video out plug. This also includes the USB wiring harness adapter that lets you reprogram and customize both my device and the MinimOSD - without it the MinimOSD is pretty useless, which is why I'm bundling it.
Das Manual :
http://firebug24k.com/fbosd/fbosd_setup.pdf
Link zum Shop:
http://firebug24k.com/index.php
Hi, gibt es die Beschreibung schon in deutsch ?
Sagt mir trotz Googel Übersetzer fast garnichts.
L.G. udo
wolfes1126
Interessantes Thema, vor allem da es ja mit der GPS ANtenne von Kopter zu Kopter wandern könnte ...
Jay ist übrigens ein sehr netter Kontakt.
Boarder
Kurzer Zwischenstand :
W. 2x Gold
P. 1x Bronze
M. 1xG
K. 1xG
A. 1xG
Ap. 1xG
L. 1xG
H. 1xS
K. 1xG
Kie 1xG
He 1xG
F. 2xG
S. 1xG
Po. 1xG
Mr. 1xG
B. 1xG
Lo 1xG
Jo 1xG
Ki 1xG
Jeder der mir eine PN geschickt sollte in der Liste stehen.
Möchte aus Datenschutzgründen die Nicknames nicht ausschreiben.
Habe jetzt mal 19xGold, 1x Silver, 1x Bronze bei Jay angefragt.
Grüße,
Chris
PS: Das ist weiterhin eine unverbindliche Anfrage.
Koiudo
#55
Moin, welcher von den dreien würde mir denn die Höhe & Entfernung auf meiner Funke MX16 Hott anzeigen, wenn ich ohne Brille fliege ?
Danke
L.G. Udo
Boarder
der Gruppenkauf wird nicht stattfinden.
Jay würde uns 10% Rabatt auf jedes Board geben - das bedeutet im Beispiel des "Gold" Boardes :
67,50 $ + 3,50 $ Versand ( 70$ Gesamtversandkosten / 20)
Macht pro Board ca. 71 $
71$ ca. 55 Euro
55 EUro hört sich erst mal toll an, aber darauf kommt noch 19% MwSt und eine Zollgebühr von sicher mind. 5%.
Dann wären wir also bei ca 69 Euro - dazu kommt dann noch 25 Cent für den Luftpolsterumschlag und mind. 1.45 Euro als Briefversand.
Gesamtsumme pro Goldboard : ca 71 Euro
Bei einem Direktkauf inkl. Express Versand ist man bei 90$ - ca. 69 Euro. Darauf kommt ja nur noch die 19% Mwst (Zollgebühr entfällt weil Gesamtsumme unter 150 Euro ist)
Gesamtsumme pro Goldboard : ca 81 Euro
Man spart also 10 Euro - und das ist mir einfach zu wenig für den Stress :)
Bedanke mich für euer Interesse und ich werde mir auf jeden Fall ein Board bestellen.
Grüße,
Chris
