iNav
Ralf W.
Hier mein aktueller CLI Dump. Das ist noch nicht optimal - aber es funktioniert bereits beeindruckend.
Die wichtigste Änderung war für meinen Tri die Senkung von set p_level von 20 auf 16.
Code:
# version
# INAV/NAZE 1.2.0 Sep 7 2016 / 11:26:35 (6cc415a)
# pflags
# Persistent config flags: 0x00000001
# dump master
# mixer
mixer TRI
mmix reset
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_NRF24
feature -SOFTSPI
feature RX_PPM
feature MOTOR_STOP
feature GPS
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
# serial
serial 0 1 115200 38400 0 115200
serial 1 2 115200 57600 0 115200
set looptime = 2000
set i2c_overclock = OFF
set gyro_sync = OFF
set gyro_sync_denom = 16
set mid_rc = 1500
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = ON
set input_filtering_mode = OFF
set min_throttle = 1064
set max_throttle = 1850
set min_command = 1000
set servo_center_pulse = 1500
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 1000
set motor_pwm_rate = 400
set servo_pwm_rate = 300
set disarm_kill_switch = ON
set auto_disarm_delay = 5
set small_angle = 25
set reboot_character = 82
set gps_provider = UBLOX
set gps_sbas_mode = EGNOS
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set inav_accz_unarmedcal = ON
set inav_use_gps_velned = ON
set inav_gps_delay = 200
set inav_gps_min_sats = 6
set inav_w_z_baro_p = 0.350
set inav_w_z_gps_p = 0.200
set inav_w_z_gps_v = 0.500
set inav_w_xy_gps_p = 1.000
set inav_w_xy_gps_v = 2.000
set inav_w_z_res_v = 0.500
set inav_w_xy_res_v = 0.500
set inav_w_acc_bias = 0.010
set inav_max_eph_epv = 1000.000
set inav_baro_epv = 100.000
set nav_disarm_on_landing = ON
set nav_use_midthr_for_althold = OFF
set nav_extra_arming_safety = ON
set nav_user_control_mode = ATTI # CRUISE
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_max_speed = 600
set nav_max_climb_rate = 500
set nav_manual_speed = 2000  # 500
set nav_manual_climb_rate = 500
set nav_landing_speed = 350
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 500
set nav_rth_tail_first = OFF
set nav_rth_alt_mode = AT_LEAST
set nav_rth_altitude = 1000
set nav_mc_bank_angle = 30
set nav_mc_hover_thr = 1500
set nav_mc_auto_disarm_delay = 2000
set nav_fw_cruise_thr = 1400
set nav_fw_min_thr = 1200
set nav_fw_max_thr = 1700
set nav_fw_bank_angle = 20
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 15
set nav_fw_pitch2thr = 10
set nav_fw_roll2pitch = 75
set nav_fw_loiter_radius = 5000
set serialrx_provider = SPEK1024
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = OFF
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_coordinates_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_sound_interval = 5
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set current_meter_scale = 400
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = CW90FLIP
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 1800
set gyro_lpf = 42HZ
set moron_threshold = 32
set imu_dcm_kp = 2500
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 200
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set servo_lowpass_enable = OFF
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = SET-THR
set rx_min_usec = 885
set rx_max_usec = 2115
set acc_hardware = 0
set baro_use_median_filter = ON
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set blackbox_device = SPIFLASH
set magzero_x = 18
set magzero_y = -122
set magzero_z = -15
set acczero_x = 36
set acczero_y = 47
set acczero_z = -165
set accgain_x = 4087
set accgain_y = 4085
set accgain_z = 4072
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
# dump profile
# profile
profile 0
# aux
aux 0 3 1 900 1700   # Blackbox
aux 1 10 1 900 1300  # POSHOLD
aux 2 22 0 900 1700  # ALTHOLD
aux 3 24 0 925 1325
aux 4 25 2 975 1975
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1000 2000 1500 90 90 100 -1
servo 1 1000 2000 1500 90 90 100 -1
servo 2 1000 2000 1500 90 90 100 -1
servo 3 1000 2000 1500 90 90 100 -1
servo 4 1000 2000 1500 90 90 100 -1
servo 5 1150 1850 1500 90 90 100 -1
servo 6 1000 2000 1500 90 90 100 -1
servo 7 1000 2000 1500 90 90 100 -1
set nav_alt_p = 50
set nav_alt_i = 0
set nav_alt_d = 0
set nav_vel_p = 100
set nav_vel_i = 50
set nav_vel_d = 10
set nav_pos_p = 65
set nav_pos_i = 120
set nav_pos_d = 10
set nav_posr_p = 180
set nav_posr_i = 15
set nav_posr_d = 100
set nav_navr_p = 10
set nav_navr_i = 5
set nav_navr_d = 8
set deadband = 5
set yaw_deadband = 5
set throttle_tilt_comp_str = 0
set flaperon_throw_offset = 250
set flaperon_throw_inverted = OFF
set mode_range_logic_operator = OR
set default_rate_profile = 0
set gimbal_mode = NORMAL
set mag_declination = 160
set mag_hold_rate_limit = 90
set p_pitch = 35
set i_pitch = 25
set d_pitch = 12
set p_roll = 35
set i_roll = 25
set d_roll = 13
set p_yaw = 70
set i_yaw = 45
set d_yaw = 0
set p_level = 16
set i_level = 15
set d_level = 75
set max_angle_inclination_rll = 450
set max_angle_inclination_pit = 450
set gyro_soft_lpf_hz = 60
set acc_soft_lpf_hz = 15
set dterm_lpf_hz = 40
set yaw_lpf_hz = 30
set yaw_p_limit = 300
set iterm_ignore_threshold = 200
set yaw_iterm_ignore_threshold = 50
set rate_accel_limit_roll_pitch = 0
set rate_accel_limit_yaw = 10000
# dump rates
# rateprofile
rateprofile 0
set rc_expo = 30
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 40
set pitch_rate = 40
set yaw_rate = 50
set tpa_rate = 0
set tpa_breakpoint = 1500
pacman111178
@Schalonsus ... heute mit Inav1.2 Stable auf dem Nuri geflogen ... oh man ... es war ein wenig wind heute .. ist geflogen wie ne Flugente ... so schlecht ist der noch nie geflogen .. naja PosHold konnte er ausführen ... und siehe da er taucht immer noch nicht ! Habe jetzt noch ein paar werte von dir übernommen .. aber das wichtigste was ich gemacht habe , Ich habe den Backstein mal oben drauf gepackt .. in Form eines 5200mah Lipos . mal sehen ob er jetzt ... taucht .. das heisst wenn ich ihn in die luft bekomme ... irgendwie finde ich unter 1.2 noch nicht den richtigen Mode ...
und der Led Strip geht auf dem F3 Board auch nicht .. bekomme mal gerade die Fehler angezeigt ob er gearmt ist oder nicht ist schon nicht mehr drin . Irgendwie ist INav1.2 ein schritt Zurück ...
Gruß Boris
Kann ich jetzt mit der 1.2er Version.... Bedenkenlos die PID Werte von Cleanflight übernehmen ( die Standartwerte sind schon perfekt für meine Flieger) und in iNav übertragen?
(Falls das andere sind)
Mit CF fliegt der einfach wahnsinnig gut.. bei iNav (1.1.... die 1.2er kommt ab morgen im Einsatz) flog er sehr "zögerlich".
@pacman
Ich hab ab morgen 2 identlische Kopter rumliegen, nur die Motoren/ESCs sind vom anderen Hersteller... aber das macht sich bisher nicht wirklich bemerkbar.
Ab nächte Woche 3 identische.... ( einer soll ein reiner Racer sein, einer mit GPS RTH Funktion, beide mit FPV-Möglichkeit, der dritte rein GPS und gute Kam)
bevor die ganzen Peripherien drann kommen.... kann ich auch einen Echtzeittest mit drei Verschiedenen Firmware machen...falls du das willst ;)
Werde mir dann eh mal einen "Überblick" machen, wie sich Betaflight, Cleanflight und iNav verhalten...
pacman111178
@ Alex ich habe 2 Kopter und einen Nuri mit Inav 1.2 und einen Racer mit CF . Mein grosser 650er Kopter hat ne Apm drin !
Die Kopter fliegen auch Super mit Inav aber der Nuri nicht .. ich glaube es liegt aber am Nuri ..
Gruß Boris
pacman111178
Also Für Inav 1.1 auf 1.2 gibts ne Umrechnungstabelle .
Von CF nach Inav 1.2 kann ich dir nicht sagen ob es passt .. aber du wirst es merken [emoji6] .
Ich habe mal von ner alten CF version auf die letzte CF version gewechselt und er ist geflogen wie ne schalftablette!
Achso ... und wenn ich bei der Telemetrie Mavlink anwähle und ihn nachher scharf schalte geht gleichzeitig die Mavlink verbindung zu bruch ..... komischer Mavlink
Gruß Boris
Brot
Die Umrechnung von 1.1 auf 1.2 hat bei mir nicht funktioniert.
Mit 1.1 flog er schon gut. Mit 1.2 musste ich nach 5 Sekunden in der Luft sehr schnell landen. Der Copter war sehr stark am taumeln.
Alles Werte gecheckt und CLI durchgeguckt. Alles gut.
Nach mehreren Versuchen habe ich dann den PID Controller Resetet und die Rates angepasst. Jetzt fliegt er schon mal wieder recht stabil.
Eine Umrechnung von CF auf INav könnte schwer werden. Da INAV ja auch einen anderen PID Controller benutzt als CF.
Gruß Flo
Schalonsus
Gruß Boris
Hört sich nach einem spannenden Flug an :D
Glaube deine PIDs sind zu niedrig. Bzw halt nur die P Werte für Roll und Pitch. Versuch die mal schrittweise zu erhöhen bis es um die jeweilige Achse anfängt zu oszillieren. Dann wieder 0.5 oder 1.0 runter. So ein Flieger kann um einiges bockiger sein als ein Copter...
Fliegt der Nuri denn gescheit im Passthrough Modus? Neutrallage der Ruder stimmt?
wer Lesen kann... in den iNav Wikis bei PID Tuning:
" In Cleanflight v1.13.0 the MWREWRITE and LUX PID controllers were equalised so that the same PID settings can be used with those two PID controllers (subject to a small margin of error)."
Ralf W.
Hallo Boris,
welche Werte hast Du denn eingestellt? Hast Du Werte von iNAV 1.1 oder von CF übernommen? Unverändert oder umgerechnet?
Ein aktueller CLI-Dump könnte auch helfen, sinnvolle Ratschläge zu geben.
In jedem Fall gilt für den Wechsel zu iNAV 1.2 (egal von welcher bisherigen Firmware)
new_rate = old_rate + 20
also z.B.
set pitch_rate = 40 # wenn bisher 20
set roll_rate = 30 # wenn bisher 10
weil es keine generelle rc_rate mehr gibt.
Und dann die wichtige Frage von Schalonsus: Fliegt Dein Nuri im Passthrough Mode vernünftig?
Und ich weiß nicht mehr, in welchem Mode Du den Nuri normalerweise fliegst.
pacman111178
Hi Schalonsus ...der Flug war es geht so ... Schwerfällig ... Passtrouth geht wenn man gerade fliegt ... aber die Vollausschläge sind noch zu gross .. wollte das eventuell an den Servohebeln noch kürzen und nicht in der Software. Getaucht hat er aber nicht so richtig trotz Backstein. aber ich habe festgestellt .. bei INav1.1 musste ich im Board Mangment Pitch - 40 eingeben bei Inav 1.2 muss ich auf einmal + 40 eingeben !!!
Gruß Boris
pacman111178
@ Ralf ... Ich tappe voll im Dunkeln mit den Pids aber ich weiss das wenn ich bei P pitsch 20 eingebe dann fängt er bei Highspeed flügen an zu schlagen bei 15 ist alles ok . Jetzt durch das Kürzen der Servowege könnte es aber durchaus sein das ich wieder rauf muss mit dem wert . Was mich ein wenig nervt ist das er so lange brauch wenn ich in Angle Mode voll nach rechts lenke dann brauch er 2 Sekunden bis er sich voll in die kurve lehnt ... habe jetzt den Level wert hoch gestellt aber ich musste eben wieder pausieren da wieder ein Propeller hin war ! Heute 2 Normale und 1 Klapppropeller zerlegt !
Gruß Boris
pacman111178
Hier mein jetziger Nuri Dump:
Entering CLI Mode, type 'exit' to return, or 'help'
dump
dump
# version
# INAV/SPRACINGF3 1.2.0 Sep 7 2016 / 11:32:00 (6cc415a)
# pflags
# Persistent config flags: 0x00000000
# dump master
# mixer
mixer FLYING_WING
mmix reset
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -3D
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_NRF24
feature -SOFTSPI
feature RX_PPM
feature VBAT
feature MOTOR_STOP
feature GPS
feature FAILSAFE
feature LED_STRIP
feature BLACKBOX
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
# serial
serial 2 1 19200 38400 0 115200
# led
led 0 4,14::CW:6
led 1 5,14::CW:6
led 2 6,14::CW:6
led 3 7,14::CW:6
led 4 8,14::CW:6
led 5 9,14::CW:6
led 6 10,14::CW:6
led 7 11,14::CW:6
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
set looptime = 2000
set gyro_sync = OFF
set gyro_sync_denom = 2
set mid_rc = 1500
set rssi_scale = 30
set min_throttle = 1045
set min_command = 1045
set 3d_deadband_throttle = 1045
set servo_pwm_rate = 50
set disarm_kill_switch = OFF
set gps_sbas_mode = AUTO
set inav_auto_mag_decl = ON
set nav_disarm_on_landing = OFF
set nav_max_speed = 300
set nav_manual_speed = 500
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_fw_cruise_thr = 1700
set nav_fw_min_thr = 1580
set nav_fw_max_thr = 1800
set nav_fw_bank_angle = 35
set nav_fw_climb_angle = 13
set nav_fw_pitch2thr = 20
set nav_fw_roll2pitch = 35
set nav_fw_loiter_radius = 3500
set telemetry_inversion = ON
set align_mag = DEFAULT
set align_board_pitch = 60
set align_board_yaw = 0
set gyro_lpf = 42HZ
set imu_dcm_ki = 50
set baro_hardware = 1
set mag_hardware = 1
set blackbox_rate_denom = 16
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set acczero_x = 65
set acczero_y = 68
set acczero_z = -489
set ledstrip_visual_beeper = OFF
set accgain_x = 4054
set accgain_y = 4059
set accgain_z = 4040
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
# dump profile
# profile
profile 0
# aux
aux 0 1 1 1425 1625
aux 1 25 1 2025 2100
aux 2 3 0 1025 1100
aux 3 3 0 2025 2100
aux 4 10 0 1025 1100
aux 5 9 2 1025 1100
aux 6 24 1 900 1250
aux 7 11 1 1900 2000
aux 8 12 2 1025 1100
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 3 1130 1750 1550 90 90 -80 -1
servo 4 1250 1830 1450 90 90 80 -1
servo 5 1000 2000 1500 90 90 100 -1
set nav_alt_p = 50
set nav_alt_i = 0
set nav_alt_d = 0
set nav_vel_p = 100
set nav_vel_i = 50
set nav_vel_d = 10
set nav_pos_p = 65
set nav_pos_i = 120
set nav_pos_d = 0
set nav_posr_i = 15
set nav_navr_p = 50
set nav_navr_i = 5
set nav_navr_d = 8
set deadband = 5
set mag_declination = 0
set p_pitch = 10
set i_pitch = 8
set d_pitch = 20
set p_roll = 60
set i_roll = 8
set d_roll = 44
set p_yaw = 70
set i_yaw = 16
set d_yaw = 0
set p_level = 30
set i_level = 15
set d_level = 75
set max_angle_inclination_rll = 400
set max_angle_inclination_pit = 300
set yaw_lpf_hz = 30
# dump rates
# rateprofile
rateprofile 0
set rc_expo = 70
set thr_mid = 50
set thr_expo = 0
set roll_rate = 20
set pitch_rate = 20
set yaw_rate = 20
set tpa_rate = 0
set tpa_breakpoint
Gruß Boris
Schalonsus
Ich bin mittlerweile auch ratlos was dein Nuri angeht. Ich denke aber du hast villt grundlegend was mechanisch falsch eingestellt.
Wie fliegt sich das Teil im Horizon Mode?
Im Angle Mode fliegt sich meiner halt auch sehr eingeschränkt. Sinken tut er auch extrem langsam, deswegen flieg ich meistens Horizon und nur für Longrange im Angle wo ich einfach eine Höhe und Kurs halten möchte.
Im Passthrough lässt sich meiner gut fliegen, das sollte er aber auch weil es sonst sehr schwierig ist für die FC den zu steuern.
talentfrei
Also Jungs, mann soll es erst ohne FC einfliegen und so einstellen das es gut auf die Knüppel gut reagiert ohne übersteuern. Dann das FC einbauen und testen....
pacman111178
@Talentfrei der Nuri ist schon 2Jahre alt und ist Manuell und mit Cc3d geflogen , er ist sogar mit SpracingF3 Fc super geflogen .. nur hat er auf einmal einen knacks irgendwo im System das er nicht mehr im Poshold Modus sinkt ... damit hat es angefangen . Natürlich sinkt er auch nicht beim Waypoints fliegen .
Was ist denn wenn die Bootpins dauerhaft gebrückt wären ?
Meine sind etwas zermatscht !
Gruß Boris
gfacek
Kann es sein, dass es den Cruise Mode nur beim F3 gibt?
EDIT: Also, ich habe jetzt auch mal den SPRF3 angeschlossen und 1.2 geflasht. Auch hier sehe ich keinen Cruise Mode.
Wo finde ich den denn?
