Hi
Nachdem ich jetzt schon 1 1/2 Stunde vorm PC sitze, komme ich hier nicht weiter. Ein Kollege hatte mir die kompletten Dateien heruntergeladen. Mit dem Arduino 1.02 kommt ne Meldung:"expected class-name before '{'token"
In file included from ArduCam_Max7456.cpp:4:
ArduCam_Max7456.h:78: error: expected class-name before '{' token
ArduCam_Max7456.h:84: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:87: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:90: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:97: error: 'size_t' does not name a type
ArduCam_Max7456.h:98: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:99: error: 'BetterStream' has not been declared
ArduCam_Max7456.h:101: error: 'uint8_t' does not name a type
ArduCam_Max7456.cpp: In member function 'void OSD::init()':
ArduCam_Max7456.cpp:38: error: 'video_mode' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'void OSD::setMode(int)':
ArduCam_Max7456.cpp:96: error: 'video_mode' was not declared in this scope
ArduCam_Max7456.cpp:97: error: 'video_center' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'int OSD::getMode()':
ArduCam_Max7456.cpp:110: error: 'video_mode' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'int OSD::getCenter()':
ArduCam_Max7456.cpp:125: error: 'video_center' was not declared in this scope
ArduCam_Max7456.cpp: At global scope:
ArduCam_Max7456.cpp:149: error: prototype for 'void OSD::setPanel(uint8_t, uint8_t)' does not match any in class 'OSD'
ArduCam_Max7456.h:84: error: candidate is: void OSD::setPanel(int, int)
penPanel()':
ArduCam_Max7456.cpp:164: error: 'row' was not declared in this scope
ArduCam_Max7456.cpp:164: error: 'col' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'void OSD::closePanel()':
ArduCam_Max7456.cpp:193: error: 'row' was not declared in this scope
ArduCam_Max7456.cpp:199: error: prototype for 'void OSD:
penSingle(uint8_t, uint8_t)' does not match any in class 'OSD'
ArduCam_Max7456.h:90: error: candidate is: void OSD:
penSingle(int, int)
ArduCam_Max7456.cpp:223: error: no 'size_t OSD::write(uint8_t)' member function declared in class 'OSD'
ArduCam_Max7456.cpp:238: error: prototype for 'void OSD::control(uint8_t)' does not match any in class 'OSD'
ArduCam_Max7456.h:87: error: candidate is: void OSD::control(int)
ArduCam_Max7456.cpp:255: error: prototype for 'void OSD::write_NVM(int, uint8_t*)' does not match any in class 'OSD'
ArduCam_Max7456.h:98: error: candidate is: void OSD::write_NVM(int, int*)
Daraufhin hab ich mir den Tortoise SVN Downloader installiert, um die Dateien erneut herunterzuladen.
Leider sagt mir das Programm, dass die erforderlichen Dateien nicht verfügbar sind.
Jetzt bin ich mit meinem Latein am Ende. Evtl. könnte mir jmd. helfen.
Gruß Karsten
