#ifndef CONFIG_H
#define CONFIG_H
/* Config file
* created by Samuel Brucksch
#define DEBUG
/** PID Values
#define P 5000 //default 2200
#define I 100 //default 280
#define D 1000 //default 20000
/* #### Atmega 2560 ####
* If using Atmega 2560 we do not need softserial, so uncomment if using an atema 2560
#define MEGA
/* #### Protocol ####
* FRSKY_D, FRSKY_X, HOTT, EXTERNAL
* FRSKY_D -> D-Series
* FRSKY_X -> Taranis / XJT
* HOTT -> MX12, MX16 and all other HoTT transmitters with telemetry
* RVOSD
* MFD -> MFD protocol will not work with local GPS!!!!
* MAVLINK -> Mavlink protocol (APM/Pixhawk/...)
* GPS_TELEMETRY -> direct NMEA input
* SERVOTEST
#define RVOSD
/* #### Baud Rate ####
* baud rate of telemetry input
* 9600 for FRSKY_D -> D-Series
* 57600 for FRSKY_X -> Taranis/XJT and MAVLINK
* 115200 for RVOSD (RVGS)
* ??? for HoTT
#define BAUD 115200
/* #### Tilt servo 0° adjustment ####
* Enter PWM value of Servo for pointing straight forward
#define TILT_0 1050
/* #### Tilt servo 90° adjustment ####
* Enter PWM value of Servo for pointing 90° up
#define TILT_90 2025
/* #### Pan servo 0° adjustment ####
* Enter PWM value of Servo for not moving
#define PAN_0 1470
/* #### Pan servo minimum required speed ####
* If the servo has problems to start a rotation when the speed is slow adjust this value until the tracker moves directly from each position
#define MIN_PAN_SPEED 30
/* #### Compass declination ####
http://magnetic-declination.com/
* Enter your city and then get the value for Magnetic declination
* for example [Magnetic declination: 3° 2' EAST]
* now enter the value in the format DEGREE.MINUTE * 10 -> 3.2 * 10 = 32
* set to 0 if you cannot find your declination!
#define DECLINATION 3
/* #### Compass offset ####
* If you did not mount your compass with the arrow pointing to the front you can set an offset here.
* Needs to be multiplied by 10 -> 90° = 900
* Range: 0 ... 3599
#define OFFSET 900
/* #### DIY GPS / Fix Type ####
* If you use the diy GPS the fix type is transmitted with the satellites on Temp2. The value is calculated like this:
* Num of Sats: 7
* Fix Type: 3
* Value = Sats * 10 + Fix Type = 7*10 + 3 = 73
* If you use the native frsky gps or fixtype is not present comment to disable.
//#define DIY_GPS
#ifndef MFD
/* #### Ground GPS ####
* !!!!!!NOT SUPPORTED YET!!!!!!!
* needed for ground gps so home does not need to be manually set
* Types:
* MTK, UBX
* UBX not implemented yet
* does not work when in MFD mode
#define LOCAL_GPS
//#define MTK
#define GPS_BAUDRATE 4800
#endif
/* #### Tracker Setup ####
* Start tracking when plane is XXX m away from tracker
* It is recommended to start tracking only if plane moved a few meters already. Default: 10m
#define START_TRACKING_DISTANCE 10
/* ### LCD Display ###
* Uncomment to display data on LCD Display
* Please choose for the Display Type:
* I2C
* SPI
* LCD Display is required for this.
* Requires modified LiquidCrystal library:
https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
#define LCD_DISPLAY I2C
#define LCD_SIZE_ROW 4 // default 2
/* ### Battery monitoring ###
* Uncomment to monitor your Battery
* Voltage divider is required for this.
//#define BATTERYMONITORING
#ifdef BATTERYMONITORING
//#define BATTERYMONITORING_RESISTOR_1 18000
//#define BATTERYMONITORING_RESISTOR_2 1000
//#define BATTERYMONITORING_CORRECTION 1.0 // default 1.0
#endif
/* #### Do not edit below this line */
#if TILT_0 < 700 || TILT_0 > 2300 || TILT_90 > 2300 || TILT_90 < 700
#error "Tilt servo range invalid. Must be between 800 and 2200."
#endif
Sorry to report that does not work me, the compass starts but my local GPS confirmed this to 1Hz 4800 gga is not on the LCD satellites.
I put my config.h if you see something wrong:
#if OFFSET < 0 || OFFSET > 3599
#error "Offset invalid. Must be between 0 and 3599."
#endif
#endif
