Mstrens hat das auf Bitten hin vor 2 Stunden den Hinweis in oXs_config_describtion.h hinzu gefügt.
**** xx - Reserved for developer. **************************************************************************************
* DEBUG must be activated in file oXs_config_macros.h when you want to debug one or several functions in some other files.
* Enabling DEBUG will allow to use Arduino Serial Monitor at 115200 baud (or 38600 when GPS is activated) to see init data and some live sensor values
* You can then select the parts that you want to debug by uncommenting the specifics DEBUG parameters you want in each file
* Note: OXS allows to transmit 3 fields named TEST1, TEST2, TEST3. You can fill those fields with whatever you want where you want if you want to transmit additional data to the Tx.
* Just fill in test1.value (or 2, 3) with an int32_t and test1.available (or 2, 3) with true and add those OXS measurements in the data to be sent section.
//#define DEBUG // !! is to define in file oXs_config_macros.h
cu KH
