// ***** 9.1 - Frsky data *****
#define VFAS_SOURCE VOLT_1 // select between VOLT_1, VOLT_2, VOLT_3 , VOLT_4, VOLT_5 , VOLT_6, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define FUEL_SOURCE ADS_VOLT_1 // select between VOLT_1, VOLT_2, VOLT_3 , VOLT_4, VOLT_5 , VOLT_6, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define A3_SOURCE ADS_VOLT_2 // select between VOLT_1, VOLT_2, VOLT_3 , VOLT_4, VOLT_5 , VOLT_6, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define A4_SOURCE ADS_VOLT_3 // select between VOLT_1, VOLT_2, VOLT_3 , VOLT_4, VOLT_5 , VOLT_6, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define ACCX_SOURCE ADS_VOLT_1 // select between TEST_1, TEST_2, TEST_3, GLIDER_RATIO , SECONDS_SINCE_T0 ,AVERAGE_VSPEED_SINCE_TO , VOLT_1, VOLT_2, VOLT_3, VOLT_4, VOLT_5, VOLT_6, PITCH, ROLL , YAW, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define ACCY_SOURCE ADS_VOLT_2 // select between TEST_1, TEST_2, TEST_3, GLIDER_RATIO , SECONDS_SINCE_T0 ,AVERAGE_VSPEED_SINCE_TO , VOLT_1, VOLT_2, VOLT_3, VOLT_4, VOLT_5, VOLT_6, PITCH, ROLL , YAW, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define ACCZ_SOURCE ADS_VOLT_3 // select between TEST_1, TEST_2, TEST_3, GLIDER_RATIO , SECONDS_SINCE_T0 ,AVERAGE_VSPEED_SINCE_TO , VOLT_1, VOLT_2, VOLT_3, VOLT_4, VOLT_5, VOLT_6, PITCH, ROLL , YAW, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
#define T1_SOURCE VOLT_2 // select between TEST_1, TEST_2, TEST_3 , GLIDER_RATIO , SECONDS_SINCE_T0 ,AVERAGE_VSPEED_SINCE_TO , SENSITIVITY, PPM, VOLT_1, VOLT_2, VOLT_3, VOLT_4, VOLT_5, VOLT_6, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
//#define T2_SOURCE ADS_VOLT_4 // select between TEST_1, TEST_2, TEST_3, , GLIDER_RATIO, SECONDS_SINCE_T0 ,AVERAGE_VSPEED_SINCE_TO , SENSITIVITY, PPM, VOLT_1, VOLT_2, VOLT_3, VOLT_4, VOLT_5, VOLT_6, ADS_VOLT_1, ADS_VOLT_2, ADS_VOLT_3, ADS_VOLT_4
