Sind Arduino und RX/TX auf diesen Bildern richtig angeschlossen ?
Das Flashen auf die neueste Firmware mit Arduino hat offenbar gefunzt, wie immer.
Bei der Benutzung des Configurator erhalte ich folgende Meldungen (Win XP):
14:27:11 -- Connection successfully opened with ID: 1
14:27:25 -- Start message not received within 10 seconds, disconnecting.
14:27:25 -- Successfully closed serial connection
14:27:37 -- Connection successfully opened with ID: 2
14:27:50 -- Start message not received within 10 seconds, disconnecting.
14:27:50 -- Successfully closed serial connection
14:28:16 -- HEX file loaded into memory, parsing ...
14:28:16 -- HEX file parsed, ready for flashing - 13732 bytes
14:28:19 -- Connection successfully opened with ID: 3
14:28:22 -- Connection to the module failed
14:28:22 -- Successfully closed serial connection
14:28:57 -- Connection successfully opened with ID: 4
14:29:00 -- Connection to the module failed
14:29:00 -- Successfully closed serial connection
14:29:08 -- Connection successfully opened with ID: 5
14:29:22 -- Start message not received within 10 seconds, disconnecting.
14:29:22 -- Successfully closed serial connection
14:30:02 -- Connection successfully opened with ID: 6
14:30:16 -- Start message not received within 10 seconds, disconnecting.
14:30:16 -- Successfully closed serial connection
14:30:20 -- HEX file loaded into memory, parsing ...
14:30:20 -- HEX file parsed, ready for flashing - 13732 bytes
14:30:25 -- Connection successfully opened with ID: 7
14:30:28 -- Connection to the module failed
14:30:28 -- Successfully closed serial connection
14:31:11 -- Connection successfully opened with ID: 8
14:31:14 -- Connection to the module failed
14:31:14 -- Successfully closed serial connection
14:31:39 -- Connection successfully opened with ID: 9
14:31:53 -- Start message not received within 10 seconds, disconnecting.
14:31:53 -- Successfully closed serial connection
14:31:57 -- You can't view tabs at the moment. You need to connect first.
14:32:11 -- Connection successfully opened with ID: 10
14:32:19 -- You can't view tabs at the moment. You need to connect first.
14:32:24 -- Start message not received within 10 seconds, disconnecting.
14:32:24 -- Successfully closed serial connection
14:32:26 -- Connection successfully opened with ID: 11
14:32:28 -- You can't view tabs at the moment. You need to connect first.
14:32:38 -- You can't view tabs at the moment. You need to connect first.
14:32:40 -- You can't view tabs at the moment. You need to connect first.
14:32:40 -- Start message not received within 10 seconds, disconnecting.
14:32:40 -- Successfully closed serial connection
