Besten Dank, Carbonator, für den Hinweis. Anbei die oXs_config.h:
// OpenXsensor
https://github.com/openXsensor/
// started by Rainer Schloßhan
// ! IMPORTANT NOTE !!!!!!!!!! Another file in this project (see oXs_config_description.h) provides detailed explanations on how to set up this file. //
// Note: the oXs_config.h file present on the GitHub site is not always meaningful.
// It could be that the combination of active/non active parameters is not consistent.
// This is just the result of many updates and tests in this document.
// So take always care to set up the oXs_config.h file according to your needs and check carefully all options.
// You can also use the oXs configurator in order to generate automatically a valid file.
#ifndef OXS_CONFIG_h
#define OXS_CONFIG_h
// --------- 1 - General protocol ---------
// ***** 1.1 - Multiplex protocol is used (otherwise oXs assumes it is Frsky protocol) *****
//#define MULTIPLEX
// ***** 1.2 - FrSky protocol and device ID (required when Sport protocol is used) *****
//#define FRSKY_TYPE_SPORT // when uncommented, it forces oXs to apply only SPORT protocol, otherwise, oXs detects automatically if protocol has to be SPORT or HUB
#define FRSKY_TYPE_HUB // when uncommented, it forces oXs to apply only HUB protocol, otherwise, oXs detects automatically if protocol has to be SPORT or HUB
#define SENSOR_ID 0x1B //0x1B
// --------- 2 - Serial data pin choice ---------
#define PIN_SERIALTX 4 // The pin which transmits the serial data to the FrSky telemetry receiver
// --------- 3 - PPM settings ---------
//#define PIN_PPM 3 // default is 2 but my own device use 3
//#define PPM_MIN_100 980 // default 1500 - 512 ; // pulse width (usec) when TX sends a channel = -100
//#define PPM_PLUS_100 1990 // default 1500 + 512 ; // pulse width (usec) when TX sends a channel = +100
// --------- 4 - Vario settings ---------
// ***** 4.1 - Connecting 1 or 2 MS5611 barometric sensor *****
//#define VARIO // set as comment if there is no vario
//#define SENSOR_IS_BMP180 // set as comment if baro sensor is MS5611
//#define VARIO2 // set as comment if there is no second vario
// ***** 4.2 - Sensitivity predefined by program *****
#define SENSITIVITY_MIN 50
#define SENSITIVITY_MAX 300
#define SENSITIVITY_MIN_AT 100
#define SENSITIVITY_MAX_AT 1000
// ***** 4.3 - Sensitivity adjusted from the TX *****
#define SENSITIVITY_MIN_AT_PPM 10 // sensitivity will be changed by OXS only when PPM signal is between the specified range enlarged by -5 / +5
#define SENSITIVITY_MAX_AT_PPM 40
#define SENSITIVITY_PPM_MIN 20 // common value for vario is 20
#define SENSITIVITY_PPM_MAX 100 // common value for vario is 100
// ***** 4.4 - Hysteresis parameter & Alt compensation based on sensor temp *****
#define VARIOHYSTERESIS 5
#define ALT_TEMP_COMPENSATION 800
// ***** 4.5 - Vertical speeds calculations *****
#define VARIO_PRIMARY 0 // 0 means first ms5611, 1 means second ms5611 , 2 means vario based on vario 1 + compensation from airspeed , 3 means average of first and second ms5611
#define VARIO_SECONDARY 2 // 0 means first ms5611, 1 means second ms5611 , 2 means vario based on vario 1 + compensation from airspeed , 3 means average of first and second ms5611
#define SWITCH_VARIO_MIN_AT_PPM 10
#define SWITCH_VARIO_MAX_AT_PPM 90
// ***** 4.6 - Analog vertical speed *****
#define PIN_ANALOG_VSPEED 3
#define ANALOG_VSPEED_MIN -3
#define ANALOG_VSPEED_MAX 3
// --------- 5 - Airspeed settings ---------
//#define AIRSPEED MS4525
#define AIRSPEED_RESET_AT_PPM 100
#define COMPENSATION_MIN_AT_PPM 60
#define COMPENSATION_MAX_AT_PPM 90
#define COMPENSATION_PPM_MIN 80
//#define COMPENSATION_PPM_MAX 140
// --------- 6 - Voltages & Current sensor settings ---------
// ***** 6.1 - Voltage Reference to measure voltages and current *****
//#define USE_INTERNAL_REFERENCE // uncomment this line if you use 1.1 volt internal reference instead of Vcc
#define REFERENCE_VOLTAGE 5000 // set value in milliVolt; if commented, oXs will use or 1100 (if internal ref is used) or 5000 (othewise)
// ***** 6.2 - Voltage parameters *****
#define PIN_VOLTAGE 0 , 1 , 2 , 3 , 4 , 5 // set this line as comment if no one voltage have to be measured, set a value to 8 for the voltage(s) not to be measured.
#define RESISTOR_TO_GROUND 0 , 13960 , 6180 , 4130 , 3000 , 2390 // set value to 0 when no divider is used for a voltage, can contains decimals
#define RESISTOR_TO_VOLTAGE 0 , 9880 , 9920 , 9870 , 9770 , 9880 // set value to 0 when no divider is used for a voltage, can contains decimals
#define OFFSET_VOLTAGE 0 , 0 , 0 , 0 , 0 , 0 // optionnal, can be negative, must be integer
#define SCALE_VOLTAGE 1 , 1 , 1 , 1 , 1 , 1 // optionnal, can be negative, can have decimals
// ***** 6.3 - Max number of Lipo cells to measure (and transmit to Tx) *****
#define NUMBEROFCELLS 6 // keep this line but set value to 0 (zero) if you do not want to transmit cell voltage.
// ***** 6.4 - Current param eters *****
#define PIN_CURRENTSENSOR 7
#define MVOLT_AT_ZERO_AMP 2500 // in millivolt
#define MVOLT_PER_AMP 20 // in milliVolt per Amp
#define RESISTOR_TO_GROUND_FOR_CURRENT 0 // put as comment or set to 0 if no divider is used
#define RESISTOR_TO_CURRENT_SENSOR 0 // put as comment or set to 0 if no divider is used
// --------- 7 - RPM (rotations per minute) settings ---------
//#define MEASURE_RPM
// --------- 8 - Persistent memory settings ---------
//#define SAVE_TO_EEPROM
//#define PIN_PUSHBUTTON 2 // default is 10 but my own device is 2
// --------- 9 - Data to transmit ---------
// ***** 9.1 - Frsky data *****
#define SETUP_FRSKY_DATA_TO_SEND \
AccX , VOLT1 , 1 , 1 , 0 , \
AccY , VOLT2 , 1 , 1 , 0 , \
AccZ , VOLT3 , 1 , 1 , 0 , \
DEFAULTFIELD , CELLS_1_2 , 1 , 1 , 0 , \
DEFAULTFIELD , CELLS_3_4 , 1 , 1 , 0 , \
DEFAULTFIELD , CELLS_5_6 , 1 , 1 , 0 , \
Vfas , VOLT6 , 1 , 100 , 0 , \
Curr , CURRENTMA , 1 , 100 , 0 ,
// ***** 9.2 - Multiplex data *****
//#define SETUP_MULTIPLEX_DATA_TO_SEND \
// 3 , ALTIMETER , 1 , 1 , 0 , -16384 , 16383 , \
// 6 , VERTICAL_SPEED , 1 , 1 , 0, -500 , 500 , \
// 5 , REL_ALTIMETER , 1 , 1 , 0 , -16384 , 16383 , \
// 7 , CELL_TOT , 1 , 1 , 0 , -16384 , 16383 , \
// 5 , ALTIMETER_MAX , 1 , 1 , 0 , -16384 , 16383 , \
// 4 , VOLT4 , 1 , 1 , 0 , -16384 , 16383
// --------- 10 - Sequencer ---------
//#define SEQUENCE_OUTPUTS 0b100000
//#define SEQUENCE_UNIT 100
//#define SEQUENCE_m100 1 , 0b100000 , 1 , 0b000000 , 1 , 0b100000 , 1 , 0b000000
//#define SEQUENCE_m75 1 , 0b100000 , 1 , 0b000000 , 2 , 0b100000 , 2 , 0b000000
//#define SEQUENCE_m50 5 , 0b100000 , 5 , 0b000000
//#define SEQUENCE_m25 5 , 0b100000 , 5 , 0b000000 , 0 , 0b100000
//#define SEQUENCE_0 3 , 0b100000 , 1 , 0b000000
//#define SEQUENCE_25 2 , 0b100000 , 2 , 0b000000
//#define SEQUENCE_50 5 , 0b100000 , 5 , 0b000000
//#define SEQUENCE_75 7 , 0b100000 , 7 , 0b000000
//#define SEQUENCE_100 8 , 0b100000 , 8 , 0b000000
//#define SEQUENCE_LOW 10 , 0b100000 ,10 , 0b000000 // sequence for Low voltage
//#define SEQUENCE_MIN_VOLT_6 4000 // sequence_100 will be activated if voltage 6 is lower that the value.
//#define SEQUENCE_MIN_CELL 3000 // sequence_100 will be activated if lowest cell is lower that the value.
// --------- 11 - Reserved for developer. DEBUG must be activated here when we want to debug one or several functions in some other files. ---------
//#define DEBUG
#ifdef DEBUG
#include "HardwareSerial.h"
#endif
#endif// End define OXS_CONFIG_h
