Probiere gerade das easyosd aufzuspielen aber kommt ne fehler meldung weiß gerade nicht was das heißt
In file included from ArduCam_Max7456.cpp:4:
ArduCam_Max7456.h:78: error: expected class-name before '{' token
ArduCam_Max7456.h:84: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:87: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:90: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:97: error: 'size_t' does not name a type
ArduCam_Max7456.h:98: error: 'uint8_t' has not been declared
ArduCam_Max7456.h:99: error: 'BetterStream' has not been declared
ArduCam_Max7456.h:101: error: 'uint8_t' does not name a type
ArduCam_Max7456.cpp: In member function 'void OSD::init()':
ArduCam_Max7456.cpp:38: error: 'video_mode' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'void OSD::setMode(int)':
ArduCam_Max7456.cpp:92: error: 'video_mode' was not declared in this scope
ArduCam_Max7456.cpp:93: error: 'video_center' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'int OSD::getMode()':
ArduCam_Max7456.cpp:106: error: 'video_mode' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'int OSD::getCenter()':
ArduCam_Max7456.cpp:121: error: 'video_center' was not declared in this scope
ArduCam_Max7456.cpp: At global scope:
ArduCam_Max7456.cpp:145: error: prototype for 'void OSD::setPanel(uint8_t, uint8_t)' does not match any in class 'OSD'
ArduCam_Max7456.h:84: error: candidate is: void OSD::setPanel(int, int)
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
penPanel()':
ArduCam_Max7456.cpp:160: error: 'row' was not declared in this scope
ArduCam_Max7456.cpp:160: error: 'col' was not declared in this scope
ArduCam_Max7456.cpp: In member function 'void OSD::closePanel()':
ArduCam_Max7456.cpp:189: error: 'row' was not declared in this scope
ArduCam_Max7456.cpp:195: error: prototype for 'void OSD:
penSingle(uint8_t, uint8_t)' does not match any in class 'OSD'
ArduCam_Max7456.h:90: error: candidate is: void OSD:
penSingle(int, int)
ArduCam_Max7456.cpp:219: error: no 'size_t OSD::write(uint8_t)' member function declared in class 'OSD'
ArduCam_Max7456.cpp:234: error: prototype for 'void OSD::control(uint8_t)' does not match any in class 'OSD'
ArduCam_Max7456.h:87: error: candidate is: void OSD::control(int)
ArduCam_Max7456.cpp:251: error: prototype for 'void OSD::write_NVM(int, uint8_t*)' does not match any in class 'OSD'
ArduCam_Max7456.h:98: error: candidate is: void OSD::write_NVM(int, int*)
kann mir kurz einer helfen dabei wäre echt nett .
Gruß Rene
