Ansonsten gibt es inzwischen anscheinend noch ne Lösung... Für etwa 13€/ bei glb etwa 18€. Berichte, wenns da is
#ifndef FLIGHT_BATT_H_
#define FLIGHT_BATT_H_
#define VOLTAGE_PIN 6
#define CURRENT_PIN 7
#define REF_VOLTAGE 1.1 // INTERNAL: a built-in reference, equal to 1.1 volts on the ATmega168 or ATmega328
#define LOW_VOLTAGE 9.6 // filter start value for 3s LiPo
#define VOLT_DIV_RATIO 15.55 // Vref 1.1V based: This is the start value for calibrating a 16k0/1k1 voltage divider usable up to 4s LiPo
// !!! for the +-50A Current Sensor(AC/DC) DFRobot SEN0098 we need approx. a 1/4 voltage divider 3k0/1k1 so that we stay below 1.1 V -> 2*50A * 0.04V/A / (4.1/1.1) = 1.073 V !!!
#define CURR_AMP_PER_VOLT 100.00 // Vref 1.1V based: This is the start value for calibrating a +-50A Current Sensor(AC/DC) DFRobot SEN0098 Sensitivity: 40 mV/A
#define CURR_AMPS_OFFSET 0.5000 // Vref 1.1V based: This is the start value for calibrating a +-50A Current Sensor(AC/DC) DFRobot SEN0098 Sensitivity: 40 mV/A
#define CURRENT_VOLTAGE(x) ((x)*REF_VOLTAGE/1024.0)*(volt_div_ratio/100.0)
#define CURRENT_AMPS(x) (((x)*REF_VOLTAGE/1024.0)-(curr_amp_offset/10000.0))*(curr_amp_per_volt/100.0)
void flight_batt_init(void);
void flight_batt_read(void);
#endif /* FLIGHT_BATT_H_ */
