Wenn die Werte nur mal braucht, um das Zusammenspiel der Komponenten zu prüfen...
Da hab ich massive Probleme beim hinterher hecheln mit dem Infrarotthermometer
Ich bin nicht mehr der Jüngste
// ***** 6.2 - Voltage parameters *****
#define PIN_VOLTAGE 0 , 8 , 8 , 8 , 8 , 8 // Fill 6 values; set to 0 up to 7 for analog pins A0 up to A7 ; set the value to 8 for the voltage(s) not to be measured.
#define RESISTOR_TO_GROUND 1 , 10 , 10 , 10 , 0 , 18 // set value to 0 when no divider is used for a voltage; can contains decimals
#define RESISTOR_TO_VOLTAGE 1 , 73 , 110 , 27 , 0 , 47 // set value to 0 when no divider is used for a voltage; can contains decimals
#define OFFSET_VOLTAGE 500, 0 , 0 , 0 , 0 , 0 // optionnal, can be negative, must be integer, in principe in mv
#define SCALE_VOLTAGE 1.0, 1.0 , 1.0 , 1.0 , 1.0 , 1.0 // optionnal, can be negative, can have decimals
For SPORT protocol, oXs uses up to 6 SPORT_SENSOR_ID. The 6 SENSOR_ID used by oXs are by default :
* DATA_ID_VARIO 0x00 // = sensor 0 used for Alt and Vspeed
* DATA_ID_FLVSS 0xA1 // 1 used for Cell values
* DATA_ID_FAS 0x22 // 2 used for vfas , current and fuel
* DATA_ID_GPS 0x83 // 3 used for GPS data
* DATA_ID_RPM 0xE4 // 4 used for rpm, T1, T2, airspeed
* DATA_ID_ACC 0x67 // 7 used for Acc X, Y, Z
